查看: 12275|回复: 2
[基础教程] HA+KODI安装
发表于 2017-10-16 09:10:20 | 显示全部楼层 |阅读模式
说明:本人菜鸟一枚,全是自己摸索学习的,不对的地方请指教。
安装很简单注意一下几点就可以了
1.根据老高的帖子http://bbs.feng.com/forum.php?mod=viewthread&tid=10878311&fromuid=42111搭建HA的时候,homebridge           #####这里先运行一次程序######会出现一个警告忽略就可以,如果一定想解决的话就在这里添加
sudo nano config.json
    "bridge": {
        "name": "Homebridge",
        "username": "XX:XX:XX:XX:XX:XX",
        "port": 51826,
        "pin": "123-45-678"
    "platforms": [
    "platform": "HomeAssistant",
    "name": "HomeAssistant",
    "host": "http://10.10.1.31:8123",
    "password": "raspberry",
    "default_visibility": "visible",//此处解决报错
    "supported_types": ["fan", "garage_door", "input_boolean", "light", "lock", "media_player", "rollershutter", "scene", "switch"]
2.安装KODI根据此贴https://bbs.hassbian.com/forum.php?mod=viewthread&tid=402&highlight=%E6%A0%91%E8%8E%93%E6%B4%BE
我安装的时候sudo apt-get install kodi正常安装
输入kodi会报错,所以更新了一下系统就OK了
sudo apt-get update
sudo apt-get dist-upgrade
发表于 2017-10-18 16:48:07 | 显示全部楼层
大家同菜,,哈哈。。
North丶
活跃会员卓越贡献
发表于 2017-10-19 18:41:06 | 显示全部楼层
kodi是个好东西
GMT+8, 2025-9-4 15:33 , Processed in 1.059968 second(s), 11 queries , MemCached On.
