查看: 4034|回复: 4
[已解决] 安装homeassistant在手机上
发表于 2021-11-1 09:19:28 | 显示全部楼层 |阅读模式
(my_env_PY) root@localhost:~# pip install homeassistant
Looking in indexes: http://mirrors.aliyun.com/pypi/simple/
Collecting homeassistant
  Using cached http://mirrors.aliyun.com/pypi/p ... .5-py3-none-any.whl (10.2 MB)
Collecting ruamel.yaml==0.15.100
  Using cached http://mirrors.aliyun.com/pypi/p ... aml-0.15.100.tar.gz (318 kB)
  Preparing metadata (setup.py) ... error
  ERROR: Command errored out with exit status 1:
   command: /usr/local/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-zgc06pdl/ruamel-yaml_47ee40ed0eb246a584cbd2d3e18f9388/setup.py'"'"'; __file__='"'"'/tmp/pip-install-zgc06pdl/ruamel-yaml_47ee40ed0eb246a584cbd2d3e18f9388/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-2m3yjdj0
       cwd: /tmp/pip-install-zgc06pdl/ruamel-yaml_47ee40ed0eb246a584cbd2d3e18f9388/
  Complete output (11 lines):
    File "<string>", line 1, in <module>
    File "/usr/local/lib/python3.7/site-packages/setuptools/__init__.py", line 19, in <module>
      from setuptools.dist import Distribution
    File "/usr/local/lib/python3.7/site-packages/setuptools/dist.py", line 38, in <module>
      from setuptools import windows_support
    File "/usr/local/lib/python3.7/site-packages/setuptools/windows_support.py", line 2, in <module>
      import ctypes
    File "/usr/local/lib/python3.7/ctypes/__init__.py", line 7, in <module>
      from _ctypes import Union, Structure, Array
  ModuleNotFoundError: No module named '_ctypes'
WARNING: Discarding http://mirrors.aliyun.com/pypi/p ... 526f888e026854db2e4 (from http://mirrors.aliyun.com/pypi/simple/ruamel-yaml/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
在运行了pip install homeassistant 命令后报出以上错误,根据百度,谷歌搜索出来的解决办法是貌似缺少插件,但都已经安装步骤安装好了,还是无法安装成功,有哪位大佬遇过这样的错误
我是在手机通过Linux Deploy 安装Ubuntu ,然后安装的=====================================================================================
以上方法不太推荐,我尝试了另外一个软件Alpine Linux 16.0release 版本实现了 安装homeassistant 在手机上,教程在B站有,另外安装包原作者已经删帖,不过科学上网Google一下有,有兴趣的可以自己尝试一下。
建议最好是具备科学上网的条件,所以安装包我就不发出来了。
mitu 手机认证
发表于 2021-11-1 15:23:11 | 显示全部楼层
换pip国内源试试
 楼主| 发表于 2021-11-6 09:09:50 | 显示全部楼层
mitu 发表于 2021-11-1 15:23
换pip国内源试试
我已经放弃使用LinuxDeploy 来安装,我现在使用了Alpin Term 通过安装docker 再安装homeassistant, 但是想装Hacs 的时候无法安装,一直在转圈,这个知道是什么问题吗?
mitu 手机认证
发表于 2021-11-6 13:33:38 | 显示全部楼层
klaus 发表于 2021-11-6 09:09
我已经放弃使用LinuxDeploy 来安装,我现在使用了Alpin Term 通过安装docker 再安装homeassistant, 但是 ...
最好找个梯子。。。。
 楼主| 发表于 2021-11-17 00:40:26 | 显示全部楼层
mitu 发表于 2021-11-6 13:33
最好找个梯子。。。。
我已经有梯子了,是方法不对,我之前是手动安装,后来用命令安装,安装了最新的版本,但显示不出其他集成,然后我降级了后重启homeassistant就可以了,
GMT+8, 2025-12-22 07:39 , Processed in 0.376685 second(s), 13 queries , MemCached On.
