查看: 6320|回复: 4
[求助] homeassistant怎么获得家里电脑的温度等数据
发表于 2021-10-27 14:12:22 | 显示全部楼层 |阅读模式
家里3台电脑都装了aida64,有办法让homeassistant通过aida64获得各传感器数值吗
查阅了官方文档
[size=1.2]READ VALUE OUT OF A REMOTE TEXT FILE
If you own devices which are storing values in text files which are accessible over HTTP then you can use the same approach as shown in the previous section. Instead of looking at the JSON response we directly grab the sensor’s value.
sensor:  - platform: command_line    command: python3 -c "import requests; print(requests.get('http://remote-host/sensor_data.txt').text)"    name: File value
奈何毫无编程基础,没有办法实现,有现成的办法解决吗
发表于 2021-10-27 15:03:04 | 显示全部楼层
 楼主| 发表于 2021-10-27 19:47:38 | 显示全部楼层
neroxps 发表于 2021-10-27 15:03
https://community.home-assistant.io/t/pcinfotomqtt-v0-1-3/141675
不需要编程基础
多谢,慢慢消化中
 楼主| 发表于 2021-10-27 20:52:13 | 显示全部楼层
不需要编程基础
https://www.home-assistant.io/in ... dwaremonitor/#setup
查询贴子发现直接支持Open Hardware Monitor,根据官方教程开启了Open Hardware Monitor的web服务,也修改了configuration.yaml,教程到这里没了,现在在集成里找不到OpenHardwareMonitor,请问应该怎么操作
 楼主| 发表于 2021-10-27 21:07:41 | 显示全部楼层
不需要编程基础
原来是configuration.yaml位置没写对,已经成功看到传感器了,再次感谢
GMT+8, 2025-12-22 05:46 , Processed in 0.199347 second(s), 5 queries , MemCached On.
