查看: 2426|回复: 4
[技术探讨] 第一次在VM中安装了HA,打开Web页面后不显示登录框
发表于 2021-10-27 11:00:10 | 显示全部楼层 |阅读模式
第一次在VM中安装了HA,打开Web页面后不显示登录框,如下图所示,已经半小时以上了,中间的圆点一直在动,就是看不到登录的地方。
下方的日志看不太懂,懂的帮忙看看问题出在哪里,谢了。
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[01:29:35] INFO: Using udev information from host
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[01:29:35] INFO: Starting local supervisor watchdog...
21-10-27 01:29:38 INFO (MainThread) [__main__] Initializing Supervisor setup
21-10-27 01:29:38 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
21-10-27 07:29:38 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
21-10-27 07:29:38 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2021.10.6
21-10-27 07:29:38 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
21-10-27 07:29:38 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-supervisor:2021.09.6']
21-10-27 07:29:38 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
21-10-27 07:29:38 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-10-27 07:29:38 INFO (MainThread) [__main__] Setting up Supervisor
21-10-27 07:29:39 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
21-10-27 07:29:39 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
21-10-27 07:29:39 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
21-10-27 07:29:40 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
21-10-27 07:29:40 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
21-10-27 07:29:40 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
21-10-27 07:29:40 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
21-10-27 07:29:40 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
21-10-27 07:29:40 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
21-10-27 07:29:40 INFO (MainThread) [supervisor.host.info] Updating local host information
21-10-27 07:29:40 INFO (MainThread) [supervisor.host.services] Updating service information
21-10-27 07:29:40 INFO (MainThread) [supervisor.host.network] Updating local network information
21-10-27 07:29:40 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-10-27 07:29:40 INFO (MainThread) [supervisor.host.manager] Host information reload completed
21-10-27 07:29:40 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
21-10-27 07:29:40 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
21-10-27 07:29:40 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2021.09.0
21-10-27 07:29:40 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2021.06.0
21-10-27 07:29:40 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
21-10-27 07:29:41 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2021.07.0
21-10-27 07:29:41 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
21-10-27 07:29:41 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2021.04.0
21-10-27 07:29:41 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-10-27 07:29:41 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
21-10-27 07:29:41 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
21-10-27 07:29:41 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
21-10-27 07:29:41 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 6.5 / BootSlot A
21-10-27 07:29:41 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of AdGuard Home
21-10-27 07:29:41 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot' is deprecated, 'backup' should be used instead. Please report this to the maintainer of UniFi Controller
21-10-27 07:29:41 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
21-10-27 07:29:41 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
21-10-27 07:29:42 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of AdGuard Home
21-10-27 07:29:42 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot' is deprecated, 'backup' should be used instead. Please report this to the maintainer of UniFi Controller
21-10-27 07:29:42 INFO (MainThread) [supervisor.store] Loading add-ons from store: 63 all - 63 new - 0 remove
21-10-27 07:29:42 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
21-10-27 07:29:42 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
21-10-27 07:29:42 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
21-10-27 07:29:42 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-10-27 07:29:42 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
21-10-27 07:29:42 INFO (MainThread) [__main__] Running Supervisor
21-10-27 07:29:42 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
21-10-27 07:29:42 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-10-27 07:29:42 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
21-10-27 07:29:42 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
21-10-27 07:29:42 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
21-10-27 07:29:42 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
21-10-27 07:29:42 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-10-27 07:29:42 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-10-27 07:29:42 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
21-10-27 07:29:42 INFO (MainThread) [supervisor.host.info] Updating local host information
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
21-10-27 07:29:42 ERROR (MainThread) [supervisor.utils] Can't execute check_trust while a task is in progress
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
21-10-27 07:29:42 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2021.10.6
21-10-27 07:29:42 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2021.10.6.
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
21-10-27 07:29:42 INFO (MainThread) [supervisor.host.services] Updating service information
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-10-27 07:29:42 INFO (MainThread) [supervisor.host.network] Updating local network information
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-10-27 07:29:42 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-10-27 07:29:46 INFO (MainThread) [supervisor.host.manager] Host information reload completed
21-10-27 08:29:42 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-10-27 08:29:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-10-27 08:29:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
21-10-27 08:29:42 ERROR (MainThread) [supervisor.utils] Can't execute check_trust while a task is in progress
21-10-27 08:29:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-10-27 08:29:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-10-27 08:29:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
21-10-27 08:29:42 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
21-10-27 08:29:42 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-10-27 08:29:42 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-10-27 08:29:42 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-10-27 08:29:42 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-10-27 08:29:42 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-10-27 08:32:58 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
21-10-27 08:32:58 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
21-10-27 08:32:58 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
21-10-27 08:32:58 INFO (MainThread) [supervisor.core] Supervisor is down - 100
21-10-27 08:32:58 INFO (MainThread) [__main__] Closing Supervisor
[02:34:36] WARNING: Maybe found an issue on shutdown
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[02:34:46] INFO: Using udev information from host
[cont-init.d] done.
[services.d] done.
[02:34:46] INFO: Starting local supervisor watchdog...
21-10-27 02:34:46 INFO (MainThread) [__main__] Initializing Supervisor setup
21-10-27 02:34:46 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
21-10-27 08:34:46 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
21-10-27 08:34:46 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2021.10.6
21-10-27 08:34:47 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
21-10-27 08:34:47 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-10-27 08:34:47 INFO (MainThread) [__main__] Setting up Supervisor
21-10-27 08:34:47 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
21-10-27 08:34:48 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
21-10-27 08:34:48 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
21-10-27 08:34:48 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
21-10-27 08:34:48 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
21-10-27 08:34:48 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
21-10-27 08:34:48 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
21-10-27 08:34:48 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
21-10-27 08:34:48 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
21-10-27 08:34:48 INFO (MainThread) [supervisor.host.info] Updating local host information
21-10-27 08:34:48 INFO (MainThread) [supervisor.host.services] Updating service information
21-10-27 08:34:48 INFO (MainThread) [supervisor.host.network] Updating local network information
21-10-27 08:34:49 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-10-27 08:34:49 INFO (MainThread) [supervisor.host.manager] Host information reload completed
21-10-27 08:34:49 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
21-10-27 08:34:49 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
21-10-27 08:34:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2021.09.0
21-10-27 08:34:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2021.06.0
21-10-27 08:34:49 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
21-10-27 08:34:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2021.07.0
21-10-27 08:34:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
21-10-27 08:34:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2021.04.0
21-10-27 08:34:49 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-10-27 08:34:49 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
21-10-27 08:34:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
21-10-27 08:34:49 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
21-10-27 08:34:49 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 6.5 / BootSlot A
21-10-27 08:34:49 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of AdGuard Home
21-10-27 08:34:49 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot' is deprecated, 'backup' should be used instead. Please report this to the maintainer of UniFi Controller
21-10-27 08:34:49 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
21-10-27 08:34:49 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
21-10-27 08:34:50 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of AdGuard Home
21-10-27 08:34:50 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot' is deprecated, 'backup' should be used instead. Please report this to the maintainer of UniFi Controller
21-10-27 08:34:50 INFO (MainThread) [supervisor.store] Loading add-ons from store: 63 all - 63 new - 0 remove
21-10-27 08:34:50 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
21-10-27 08:34:50 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
21-10-27 08:34:50 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
21-10-27 08:34:50 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-10-27 08:34:50 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
21-10-27 08:34:50 INFO (MainThread) [__main__] Running Supervisor
21-10-27 08:34:50 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
21-10-27 08:34:50 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-10-27 08:34:50 INFO (MainThread) [supervisor.core] Supervisor reboot detected
21-10-27 08:34:50 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-10-27 08:34:50 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-10-27 08:34:50 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
21-10-27 08:34:50 INFO (MainThread) [supervisor.host.info] Updating local host information
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-10-27 08:34:50 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2021.10.6
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-10-27 08:34:50 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2021.10.6.
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
21-10-27 08:34:50 ERROR (MainThread) [supervisor.utils] Can't execute check_trust while a task is in progress
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
21-10-27 08:34:50 INFO (MainThread) [supervisor.host.services] Updating service information
21-10-27 08:34:50 INFO (MainThread) [supervisor.host.network] Updating local network information
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-10-27 08:34:50 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-10-27 08:34:51 INFO (MainThread) [supervisor.host.manager] Host information reload completed
21-10-27 08:35:38 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
21-10-27 08:35:38 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
21-10-27 08:35:38 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
21-10-27 08:35:38 INFO (MainThread) [supervisor.core] Supervisor is down - 0
21-10-27 08:35:38 INFO (MainThread) [__main__] Closing Supervisor
[fix-attrs.d] done.
[02:36:34] INFO: Using udev information from host
[cont-init.d] done.
[services.d] done.
[02:36:34] INFO: Starting local supervisor watchdog...
21-10-27 02:36:35 INFO (MainThread) [__main__] Initializing Supervisor setup
21-10-27 02:36:35 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
21-10-27 08:36:35 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
21-10-27 08:36:35 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2021.10.6
21-10-27 08:36:35 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
21-10-27 08:36:35 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-10-27 08:36:35 INFO (MainThread) [__main__] Setting up Supervisor
21-10-27 08:36:36 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
21-10-27 08:36:36 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
21-10-27 08:36:36 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
21-10-27 08:36:36 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
21-10-27 08:36:36 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
21-10-27 08:36:36 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
21-10-27 08:36:36 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
21-10-27 08:36:36 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
21-10-27 08:36:36 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
21-10-27 08:36:36 INFO (MainThread) [supervisor.host.info] Updating local host information
21-10-27 08:36:36 INFO (MainThread) [supervisor.host.services] Updating service information
21-10-27 08:36:36 INFO (MainThread) [supervisor.host.network] Updating local network information
21-10-27 08:36:37 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-10-27 08:36:37 INFO (MainThread) [supervisor.host.manager] Host information reload completed
21-10-27 08:36:37 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
21-10-27 08:36:37 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
21-10-27 08:36:37 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2021.09.0
21-10-27 08:36:37 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
21-10-27 08:36:37 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_cli application
21-10-27 08:36:38 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2021.09.0 - 172.30.32.5
21-10-27 08:36:38 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2021.06.0
21-10-27 08:36:38 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
21-10-27 08:36:38 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_dns application
21-10-27 08:36:38 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2021.06.0 - 172.30.32.3
21-10-27 08:36:38 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
21-10-27 08:36:38 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2021.07.0
21-10-27 08:36:38 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
21-10-27 08:36:38 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_audio application
21-10-27 08:36:39 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2021.07.0 - 172.30.32.4
21-10-27 08:36:39 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
21-10-27 08:36:39 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2021.04.0
21-10-27 08:36:39 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
21-10-27 08:36:39 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_multicast application
21-10-27 08:36:39 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2021.04.0 - Host
21-10-27 08:36:39 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-10-27 08:36:39 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
21-10-27 08:36:39 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
21-10-27 08:36:39 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
21-10-27 08:36:39 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
21-10-27 08:36:39 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning homeassistant application
21-10-27 08:36:40 INFO (SyncWorker_0) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
21-10-27 08:36:40 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 6.5 / BootSlot A
21-10-27 08:36:40 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of AdGuard Home
21-10-27 08:36:40 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot' is deprecated, 'backup' should be used instead. Please report this to the maintainer of UniFi Controller
21-10-27 08:36:40 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
21-10-27 08:36:40 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
21-10-27 08:36:40 INFO (MainThread) [supervisor.store] Loading add-ons from store: 63 all - 63 new - 0 remove
21-10-27 08:36:40 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
21-10-27 08:36:40 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
21-10-27 08:36:40 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
21-10-27 08:36:40 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-10-27 08:36:40 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
21-10-27 08:36:40 INFO (MainThread) [__main__] Running Supervisor
21-10-27 08:36:40 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
21-10-27 08:36:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-10-27 08:36:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
21-10-27 08:36:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
21-10-27 08:36:40 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
21-10-27 08:36:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
21-10-27 08:36:40 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-10-27 08:36:40 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-10-27 08:36:40 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
21-10-27 08:36:40 INFO (MainThread) [supervisor.host.info] Updating local host information
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
21-10-27 08:36:40 ERROR (MainThread) [supervisor.utils] Can't execute check_trust while a task is in progress
21-10-27 08:36:40 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2021.10.6
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-10-27 08:36:40 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2021.10.6.
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
21-10-27 08:36:40 INFO (MainThread) [supervisor.host.services] Updating service information
21-10-27 08:36:40 INFO (MainThread) [supervisor.host.network] Updating local network information
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-10-27 08:36:40 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-10-27 08:36:41 INFO (MainThread) [supervisor.host.manager] Host information reload completed
ztrx 手机认证
发表于 2021-10-27 13:16:01 来自手机 | 显示全部楼层
等着
 楼主| 发表于 2021-10-27 20:24:25 | 显示全部楼层
确实又等了一段时间就好了,谢了
发表于 2021-10-27 20:40:16 | 显示全部楼层
插网线,我等了差不多两个小时,怀疑人生
发表于 2021-10-28 01:13:49 | 显示全部楼层
A17287201 发表于 2021-10-27 20:24
确实又等了一段时间就好了,谢了
哈哈 英文是硬伤
词典工具用起来,不然以后路途艰辛
GMT+8, 2026-2-3 09:50 , Processed in 1.387670 second(s), 15 queries , MemCached On.
