楼主: 秋雨轩
[进阶教程] 你是我的眼,也是我的嘴——利用萤石摄像头TTS播报
 火.. [复制链接]
发表于 2021-11-20 19:12:44 | 显示全部楼层
很厉害的样子,做个记好,还没想好拿过来怎么用
 楼主| 发表于 2021-11-20 20:15:48 来自手机 | 显示全部楼层
dinglifeng 发表于 2021-11-20 19:08
老大 请问转化成二进制数据用哪个节点作为一个NR初学者我现在是一脸懵逼,您能给做个例子么
这得看你那个tts输出来的是什么,很多节点都会自带输出二进制数据功能。你看看你那个tts输出的是啥。通用的把文件转化成二进制数据的我知道file in节点可以。比如你那个tts输出到本地一个语音mp3文件,你就可以用file in节点把这个文件转化成二进制数据。
发表于 2021-11-20 21:18:36 | 显示全部楼层
秋雨轩 发表于 2021-11-20 20:15
这得看你那个tts输出来的是什么,很多节点都会自带输出二进制数据功能。你看看你那个tts输出的是啥。通用 ...
        "id": "f475c700356aa16a",
        "type": "http-send-multipart-form-v3",
        "z": "557fd105.fe3338",
        "name": "摄像头播放",
        "filetype": "binary",
        "formparts": "",
        "ret": "txt",
        "url": "https://open.ys7.com/api/lapp/voice/sendonce",
        "tls": "",
        "sendrequest": false,
        "x": 2770,
        "y": 980,
        "wires": [
        "id": "84920f544da93720",
        "type": "function",
        "name": "整理数据",
        "func": "msg.token=global.get('萤石token')\nmsg.payload = {\n  file: {\n    field: 'voiceFile',\n    data: msg.data,\n    type: 'binary',\n    name: 'tts'\n  },\n  formOptions: {\n    accessToken: `${msg.token}`,\n    deviceSerial:'135345203',\n  }\n}\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 2580,
        "y": 980,
        "wires": [
                "f475c700356aa16a"
        "id": "2306085ccc1f3679",
        "type": "api-call-service",
        "name": "edge tts",
        "server": "d06297cb.c4f038",
        "version": 3,
        "debugenabled": false,
        "service_domain": "tts",
        "service": "edge_tts_say",
        "entityId": "media_player.xxxx",
        "data": "",
        "dataType": "jsonata",
        "mergecontext": "",
        "mustacheAltTags": false,
        "outputProperties": [
                "property": "data",
                "propertyType": "msg",
                "value": "你好啊",
                "valueType": "str"
        "queue": "none",
        "x": 2380,
        "y": 980,
        "wires": [
                "84920f544da93720"
        "id": "ece6e9261b958a42",
        "type": "function",
        "name": "TTS内容",
        "func": "var message = `主人您好,欢迎您回家。`;\nmsg.payload = {};\nmsg.payload.data = {\"message\":message};\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 2200,
        "y": 980,
        "wires": [
                "2306085ccc1f3679"
        "id": "0e088915f8025859",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 2040,
        "y": 980,
        "wires": [
                "ece6e9261b958a42"
        "id": "d06297cb.c4f038",
        "type": "server",
        "name": "Home Assistant",
        "version": 2,
        "addon": true,
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": 30
我写成这样就不知道后面怎么弄了,您能帮我看看么
发表于 2021-11-20 21:24:38 | 显示全部楼层
感谢感谢
 楼主| 发表于 2021-11-21 12:22:39 | 显示全部楼层
看了一下,你用的这个edge tts是个HA的插件,然后NR调用HA的service,这个我就不太了解了,得去问问这个插件作者,能否输出音频文件二进制数据。不过我看HA官网,tts的service应该都有个cache和cache_dir的参数可以设置。如果你那个tts插件也可以用的话,就可以把音频文件存到本地,然后用我说的file in节点再读取出来生成二进制数据,你可以试一下。
https://www.home-assistant.io/integrations/tts
发表于 2021-11-21 17:27:22 | 显示全部楼层
秋雨轩 发表于 2021-11-21 12:22
看了一下,你用的这个edge tts是个HA的插件,然后NR调用HA的service,这个我就不太了解了,得去问问这个 ...
谢谢啊 我大概明白什么意思了,我去试试看 百度现在不能领取免费的语音合成了 愁人
发表于 2021-11-21 18:07:02 | 显示全部楼层
学习一下
发表于 2021-12-5 17:26:52 | 显示全部楼层
安装http-send-multipart-form-v3后,部署时报错
节点管理里面查看发现
查看node red版本信息如下:
  Current version: 10.2.0
  Upgrades Node-RED to v2.1.4 (#1196)
不知道是否是此节点与新版本不兼容导致的,请教大家是否有解决办法?
ztrx
发表于 2021-12-7 20:08:42 | 显示全部楼层
节点管理里面查看发现
同样问题
 楼主| 发表于 2021-12-7 20:48:56 来自手机 | 显示全部楼层
节点管理里面查看发现
看样子真跟版本有关,不是node-red的版本就是node.js的版本问题。要不换换版本试一试,要不换其他http-send-multipart-form节点试试,我当时发现有好几个http-send-multipart-form节点,试了这个可以,另一个不可以用,其他的没再试了。
GMT+8, 2025-9-10 06:08 , Processed in 0.055358 second(s), 12 queries , MemCached On.
