楼主: lidicn
[插件集成] 讯飞TTS【已失效】【自定义语录】【随机语录】
 火.. [复制链接]
jove 手机认证
发表于 2018-3-27 22:53:08 | 显示全部楼层
膜拜大神!!!
dr85
发表于 2018-3-28 12:39:58 | 显示全部楼层
学习一下
严重灌水用户
发表于 2018-3-28 20:11:26 | 显示全部楼层
谢谢分享
aaax
发表于 2018-3-30 14:23:10 来自手机 | 显示全部楼层
谢谢看看
发表于 2018-4-11 20:17:38 | 显示全部楼层
学习学习
发表于 2018-4-12 17:58:08 | 显示全部楼层
必须学习一下,哎
活跃会员
发表于 2018-4-14 13:07:10 | 显示全部楼层
0.67更新后讯飞失灵了
报错
Error executing service <ServiceCall tts.iflytek_say: message=123>
  File "/usr/src/app/homeassistant/core.py", line 1002, in _event_to_service_call
    await service_handler.func(service_call)
  File "/usr/src/app/homeassistant/components/tts/__init__.py", line 135, in async_say_handle
    options=options
  File "/usr/src/app/homeassistant/components/tts/__init__.py", line 305, in async_get_url
    engine, key, message, use_cache, language, options)
  File "/usr/src/app/homeassistant/components/tts/__init__.py", line 319, in async_get_tts_audio
    message, language, options)
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/config/custom_components/tts/iflytek.py", line 183, in get_tts_audio
    data = self.message_to_tts(message=message,person_id=get_person,speed=get_speed,volume=get_volume)
  File "/config/custom_components/tts/iflytek.py", line 119, in message_to_tts
    result_info = requests.post(TOKEN_INTERFACE, data=data).json()
  File "/usr/local/lib/python3.6/site-packages/requests/models.py", line 892, in json
    return complexjson.loads(self.text, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/simplejson/__init__.py", line 518, in loads
    return _default_decoder.decode(s)
  File "/usr/local/lib/python3.6/site-packages/simplejson/decoder.py", line 370, in decode
    obj, end = self.raw_decode(s)
  File "/usr/local/lib/python3.6/site-packages/simplejson/decoder.py", line 400, in raw_decode
    return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 2 column 1 (char 2)
发表于 2018-4-15 21:16:01 | 显示全部楼层
学习学习
发表于 2018-4-18 23:30:41 | 显示全部楼层
看一下代码
发表于 2018-4-20 22:15:18 | 显示全部楼层
厉害了  我看看
GMT+8, 2026-1-14 17:43 , Processed in 0.292168 second(s), 10 queries , MemCached On.
