楼主: muxiachuixue
[学习笔记] 手把手教你解决HACS无法访问github问题:无需科学上网
发表于 2023-12-7 13:52:56 | 显示全部楼层
lambilly 发表于 2023-9-5 11:38
在configuration.yaml中添加如下代码,让packages文件夹被识别:
homeassistant:
  packages: !include_dir ...
我也是这个问题,请问您解决了吗
发表于 2023-12-17 17:04:54 | 显示全部楼层
确实方便了一些
发表于 2024-1-1 00:33:22 | 显示全部楼层
非常感谢,可以用。
发表于 2024-1-4 13:34:56 | 显示全部楼层
围观围观,6666666
发表于 2024-1-6 14:52:29 | 显示全部楼层
日志报以下错误是什么情况?怎么解决?
Logger: homeassistant.components.automation.haqi_dong_huo_mei_liang_xiao_shi_zi_dong_geng_xin_dockerzhong_githubde_hosts
Source: components/automation/__init__.py:669
Integration: 自动化 (documentation, issues)
First occurred: 14:01:00 (1 occurrences)
Last logged: 14:01:00
While executing automation automation.haqi_dong_huo_mei_liang_xiao_shi_zi_dong_geng_xin_dockerzhong_githubde_hosts
  File "/usr/src/homeassistant/homeassistant/components/shell_command/__init__.py", line 92, in async_service_handler
    stdout_data, stderr_data = await process.communicate()
  File "/usr/local/lib/python3.11/asyncio/subprocess.py", line 200, in communicate
    stdin, stdout, stderr = await tasks.gather(stdin, stdout, stderr)
  File "/usr/local/lib/python3.11/asyncio/subprocess.py", line 180, in _read_stream
    output = await stream.read()
  File "/usr/local/lib/python3.11/asyncio/streams.py", line 686, in read
    block = await self.read(self._limit)
  File "/usr/local/lib/python3.11/asyncio/streams.py", line 693, in read
    await self._wait_for_data('read')
  File "/usr/local/lib/python3.11/asyncio/streams.py", line 525, in _wait_for_data
    await self._waiter
asyncio.exceptions.CancelledError
The above exception was the direct cause of the following exception:
  File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 669, in async_trigger
    await self.action_script.async_run(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1587, in async_run
    return await asyncio.shield(run.async_run())
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 426, in async_run
    await self._async_step(log_exceptions=False)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 479, in _async_step
    self._handle_exception(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 502, in _handle_exception
    raise exception
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 476, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 713, in _async_call_service_step
    response_data = await self._async_run_long_action(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 675, in _async_run_long_action
    return long_task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 2149, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2186, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/components/shell_command/__init__.py", line 91, in async_service_handler
    async with asyncio.timeout(COMMAND_TIMEOUT):
  File "/usr/local/lib/python3.11/asyncio/timeouts.py", line 111, in __aexit__
    raise TimeoutError from exc_val
TimeoutError
发表于 2024-1-23 08:42:48 | 显示全部楼层
hacs升级还是不行.一直转圈
发表于 2024-1-23 15:50:14 | 显示全部楼层
这是一个好主意,github太慢了
发表于 2024-2-2 10:58:33 | 显示全部楼层
army2008 发表于 2024-1-1 00:33
非常感谢,可以用。
还可以用吗
发表于 2024-2-8 09:02:17 | 显示全部楼层
感谢分享,学习一下
发表于 2024-2-17 22:39:40 | 显示全部楼层
homeassistant:
小白一枚,我的也是添加这些就报错,说utf-8错误,无法重启。已强制编码了还是不行,让大神看到给指点一下。
GMT+8, 2026-2-15 01:07 , Processed in 0.014238 second(s), 3 queries , Redis On.
