查看: 3010|回复: 1
[技术探讨] 这是什么错误“Failed to setup listener for 0.0.0.0: [Errno 98] ”
发表于 2021-10-7 21:40:51 | 显示全部楼层 |阅读模式
我家云 docker下装home-assistant,启动就出现这个报错
[backcolor=var(--bg-log-line-selected-color)][cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[finish] process exit code 0
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[backcolor=var(--bg-log-line-selected-color)][services.d] starting services
[services.d] done.
2021-10-07 21:33:35 WARNING (MainThread) [homeassistant.components.ssdp] Failed to setup listener for 0.0.0.0: [Errno 98] Address in use
发表于 2021-10-8 20:08:55 | 显示全部楼层
端口已经被占用了
GMT+8, 2025-12-2 18:23 , Processed in 1.020572 second(s), 8 queries , MemCached On.
