查看: 10325|回复: 12
[技术探讨] 请大神帮看看volvooncall
发表于 2021-9-27 16:11:18 | 显示全部楼层 |阅读模式
请大神帮看看为啥参考这个教程想将VOLVO加入HASS,老是配置报错。https://www.home-assistant.io/integrations/volvooncall
https://www.wenjiangs.com/doc/home-assistant-component-car-volvo
海鲜市场:jasona3
 楼主| 发表于 2021-9-27 16:13:45 | 显示全部楼层
title: Invalid config
friendly_name: Invalid config
message: The following integrations and platforms could not be set up:
- [volvooncall](https://www.home-assistant.io/integrations/volvooncall)
Please check your config and [logs](/config/logs).
海鲜市场:jasona3
发表于 2021-9-27 17:18:06 | 显示全部楼层
 楼主| 发表于 2021-9-27 17:58:58 | 显示全部楼层
怎么改都不行,大小写,单双引号都试过。
# Example configuration.yaml entry LYVUE25D8MB768246
volvooncall:
    username: +8613500000000
    password: *******
    name:
       your_vin_number: "LYVUE25XXXXXXXXXX"
    resources:
       - lock
       - any_door_open
       - average_speed
       - position
       - engine_start
海鲜市场:jasona3
 楼主| 发表于 2021-9-27 18:01:12 | 显示全部楼层
your_vin_number 改大写会检查配置是报错。
海鲜市场:jasona3
发表于 2021-9-28 08:47:20 | 显示全部楼层
还是看log啊  log里会明确告诉你是组件加载不正确 还是配置不正确,配置的话会告诉你哪一条没配置对
 楼主| 发表于 2021-9-28 18:16:08 | 显示全部楼层
Logger: homeassistant
Source: components/volvooncall/__init__.py:167
First occurred: 18:04:55 (1 occurrences)
Last logged: 18:04:55
Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/volvooncall/__init__.py", line 167, in update
    if not await connection.update(journal=True):
  File "/usr/local/lib/python3.9/site-packages/volvooncall/volvooncall.py", line 105, in update
    user = await self.get("customeraccounts")
  File "/usr/local/lib/python3.9/site-packages/volvooncall/volvooncall.py", line 91, in get
    return await self._request(METH_GET, self._make_url(url, rel))
  File "/usr/local/lib/python3.9/site-packages/volvooncall/volvooncall.py", line 76, in _request
    response.raise_for_status()
  File "/usr/local/lib/python3.9/site-packages/aiohttp/client_reqrep.py", line 1000, in raise_for_status
    raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 401, message='Unauthorized', url=URL('https://vocapi.wirelesscar.net/customerapi/rest/v3.0/customeraccounts')
海鲜市场:jasona3
 楼主| 发表于 2021-10-18 17:05:53 | 显示全部楼层
ghostist 发表于 2021-9-28 08:47
还是看log啊  log里会明确告诉你是组件加载不正确 还是配置不正确,配置的话会告诉你哪一条没配置对 ...
LOG看不出是啥问题。
用另一个教程在Terminal中用命令成功了,可以获取车子信息,也只配置下面3个参数。
username:
password:
region:
https://github.com/eouia/MMM-VolvoOnCall
不知配置文件为啥不行?
海鲜市场:jasona3
 楼主| 发表于 2021-10-18 17:42:18 | 显示全部楼层
沃尔沃的搞定了,用户名与密码需要加双引号。
volvooncall:
  username: "XXXXXXXXXX"
  password: "XXXXXXX"
  region: cn
海鲜市场:jasona3
禁止访问
发表于 2022-11-6 17:08:53 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2026-1-16 04:50 , Processed in 1.707439 second(s), 11 queries , MemCached On.
