查看: 6922|回复: 9
[求助] modbus 485接入Home Assistant
发表于 2021-9-24 15:25:23 | 显示全部楼层 |阅读模式
之前买了个正泰DDSU666的电表,可以接入正常使用。新版是不是支持了?
configuration.yaml
modbus:
  - name: hub1
    type: rtuovertcp
    host: 192.168.100.245
    port: 502
sensor.yaml:
  - platform: modbus
    register:
      - name: 666_U
        hub: hub1
        unit_of_measurement: V
        slave: 1
        register: 8192
        data_type: float
        count: 2
        precision: 2
      - name: 666_I
        hub: hub1
        unit_of_measurement: A
        slave: 1
        register: 8194
        data_type: float
        count: 2
        precision: 2
      - name: 666_P
        hub: hub1
        unit_of_measurement: W
        slave: 1
        register: 8196
        data_type: float
        scale: 1000
        count: 2
        precision: 2
使用有人的485转网口:
貌似连是连上,就是不发数据?!
模块名称:
USR-TCP232-304
当前IP:
192.168.100.245
MAC地址:
9c-a5-25-b3-62-4b
已连接远端IP/网络发送/接收-1 :
192.168.100.248 / 0 byte / 0 byte
PS:node-red 可以正常获取数据
发表于 2021-9-25 12:08:37 来自手机 | 显示全部楼层
可以看看这个 我最近也在玩这块表 https://github.com/martgras/esphome/blob/testing/esphome/components/modbus_controller/readme.md
发表于 2021-10-6 13:45:50 | 显示全部楼层
最终结果怎么样?
 楼主| 发表于 2023-4-7 19:29:31 | 显示全部楼层
一年后填坑modbus.yaml,配置如下:
- name: hub1
    type: rtuovertcp
    host: 485转tcp IP地址
    port: 502
    sensors:
      - name: 666_voltage
        slave: 1
        address: 8192
        input_type: holding
        data_type: float32
        count: 2
        precision: 2
        device_class: voltage
      - name: 666_power_current
        slave: 1
        address: 8194
        data_type: float32
        count: 2
        precision: 2
        device_class: current
      - name: 666_power
        slave: 1
        address: 8196
        input_type: holding
        data_type: float32
        scale: 1000
        count: 2
        precision: 2
        device_class: power
      - name: 666_Freq
        unit_of_measurement: Hz
        slave: 1
        address: 8206
        input_type: holding
        data_type: float32
        count: 2
        precision: 2
        device_class: frequency
      - name: 666_totalkWh
        unit_of_measurement: kWh
        slave: 1
        address: 16384
        input_type: holding
        data_type: float32
        count: 2
        precision: 2
        device_class: energy
        state_class: total_increasing
发表于 2023-4-26 11:36:14 | 显示全部楼层
- name: hub1
    type: rtuovertcp
请问这里填啊address对应的是什么啊? 没有搞懂. 谢谢
发表于 2023-4-26 11:53:52 | 显示全部楼层
另外, 485转tcp 你用的那个东西??
 楼主| 发表于 2023-5-31 21:49:57 | 显示全部楼层
就是485寄存器地址啊,注意要把16进制转换成10进制。具体的地址要看你电表的说明书
 楼主| 发表于 2023-5-31 21:51:03 | 显示全部楼层
有人USR-TCP232-304
发表于 2023-6-2 21:50:25 | 显示全部楼层
电表接入除了统计电量有啥用?
 楼主| 发表于 2023-6-11 17:26:38 | 显示全部楼层
不是火星 发表于 2023-6-2 21:50
电表接入除了统计电量有啥用?
没啥用,家里大功率电器一开,再看一下数据。就想关了,省点电
GMT+8, 2025-12-13 16:53 , Processed in 0.054472 second(s), 12 queries , MemCached On.
