楼主: lidicn
[进阶教程] Hassbian更换数据库【提升开机速度】【提升历史查询速度】
发表于 2018-2-14 11:56:25 | 显示全部楼层
好好好好好好好好好
发表于 2018-2-14 17:38:43 | 显示全部楼层
原来自带的是什么数据库?
发表于 2018-2-15 19:52:45 | 显示全部楼层
发表于 2018-2-16 21:54:11 | 显示全部楼层
新建mysql数据库
发表于 2018-2-19 13:44:26 | 显示全部楼层
我安装时提示这个
pi@raspberrypi:~ $     sudo apt-get install mosquitto
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
mosquitto : Depends: libssl1.0.0 (>= 1.0.1) but it is not installable
             Depends: libwebsockets3 (>= 1.2) but it is not installable
E: Unable to correct problems, you have held broken packages.
Ryan
发表于 2018-2-24 01:53:02 | 显示全部楼层
我是来抢沙发的
发表于 2018-2-24 11:42:41 | 显示全部楼层
这个可以有~~~~~~~~~~~~~
发表于 2018-2-25 23:34:50 | 显示全部楼层
膜拜大神,前来学习!!
发表于 2018-2-26 09:51:19 | 显示全部楼层
学习就是进步,谢谢楼主分享
frx 手机认证
发表于 2018-2-26 09:56:40 | 显示全部楼层
看看怎么样
GMT+8, 2026-1-16 09:24 , Processed in 1.552295 second(s), 10 queries , MemCached On.
