查看: 2961|回复: 0
[基础教程] 培正电表接入HASS错误
发表于 2021-9-18 17:50:15 | 显示全部楼层 |阅读模式
看着 论坛的帖子 手痒入手了  培正电表和ESP8266模块,本来一切顺利,接入到hass出问题了 ,我是N1 docker跑的hass
错误代码如下
[color=var(--warning-color)]2021-09-18 17:47:14 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
[color=var(--error-color)]2021-09-18 17:47:14 ERROR (MainThread) [homeassistant.config] Invalid config for [homeassistant]: [dianli] is an invalid option for [homeassistant]. Check: homeassistant->dianli. (See /config/configuration.yaml, line 62).
[color=var(--warning-color)]2021-09-18 17:47:14 WARNING (MainThread) [homeassistant.bootstrap] Unable to set up core integrations. Activating safe mode
希望大佬看看什么情况
GMT+8, 2025-12-2 19:16 , Processed in 1.060396 second(s), 7 queries , MemCached On.
