楼主: XCray
[修仙教程] 【ESPHome】蓝牙体重秤/体脂秤接入思路:云麦好轻mini 2S为例
智能家居&单板滑雪痴迷爱好者
 楼主| 发表于 2022-7-21 05:57:15 | 显示全部楼层
ciasdmxhxjjpd@c 发表于 2022-7-20 21:44
3. 打印出这个广播数据,消息内容有变化,部分消息有重复,最多看到过8次:
这是你上面三个多月前问的问题呀 答案也早就有了,我看你另外一个帖子里已经用上了
发表于 2022-7-21 08:16:52 | 显示全部楼层
瞧我这记性!又忘了,找到了,谢谢
发表于 2022-10-8 22:20:07 | 显示全部楼层
我的云麦mini2也是没有数据,已经将大佬的压缩包、on_ble_advertise都烧写进去了,还是不行
这个是logs:
[22:12:54][D][ble_adv:047]: New BLE device
[22:12:54][D][ble_adv:048]:   address: 34:15:13:E7:B7:C6
[22:12:54][D][ble_adv:049]:   name: YUNMAI-ISMW2
[22:12:54][D][ble_adv:050]:   Advertised service UUIDs:
[22:12:54][D][ble_adv:052]:     - 0x1310
[22:12:54][D][ble_adv:052]:     - 0x5A05
[22:12:54][D][ble_adv:054]:   Advertised service data:
[22:12:54][D][ble_adv:058]:   Advertised manufacturer data:
[22:12:54][D][ble_adv:060]:     - 0xB7C6: (length 6)
[22:12:54][D][yunmai_scale:062]: parse_message(): payload has wrong size (6)!
这个是yaml文件
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "oQTt7A/cdMVFNuigTBhM9QKpSEK751gM3Htn6X92Nko="
ota:
  password: "9696703bd284b42e5c2fab06ea778c04"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Sff Fallback Hotspot"
    password: "OubaslR50RvM"
captive_portal:
external_components:
  - source: mine
  - platform: yunmai_scale
    mac_address: '34:15:13:E7:B7:C6'
    weight:
      name: "Yunmai Scale Weight"
    impedance:
      name: "Yunmai Scale Impedance"
esp32_ble_tracker:
  on_ble_advertise:
    - mac_address: 34:15:13:E7:B7:C6
      then:
        - lambda: |-
            ESP_LOGD("ble_adv", "New BLE device");
            ESP_LOGD("ble_adv", "  address: %s", x.address_str().c_str());
            ESP_LOGD("ble_adv", "  name: %s", x.get_name().c_str());
            ESP_LOGD("ble_adv", "  Advertised service UUIDs:");
            for (auto uuid : x.get_service_uuids()) {
                ESP_LOGD("ble_adv", "    - %s", uuid.to_string().c_str());
            ESP_LOGD("ble_adv", "  Advertised service data:");
            for (auto data : x.get_service_datas()) {
                ESP_LOGD("ble_adv", "    - %s: (length %i)", data.uuid.to_string().c_str(), data.data.size());
            ESP_LOGD("ble_adv", "  Advertised manufacturer data:");
            for (auto data : x.get_manufacturer_datas()) {
发表于 2022-10-8 22:23:16 | 显示全部楼层
iamhyde 发表于 2022-3-27 13:41
请教下我的云麦mini2得到的数据是这样
后面长度是6不是14,需要怎样修改呢,谢谢
大佬,请问你的mini2连得上了吗?我的一样是这个问题
发表于 2022-10-9 21:01:57 | 显示全部楼层
[20:37:16][D][ble_adv:075]:     - 0x20CA:0B.00.00.00.00.01.05.27.15.95.13.88.13.ED.67.27.47.7F.5F (19)    55.25
[20:35:26][D][ble_adv:075]:     - 0x20CA:0B.00.00.00.00.01.05.0F.15.18.13.88.B6.ED.67.27.47.7F.5F (19)     54
[20:39:10][D][ble_adv:075]:     - 0x20CA:0B.00.00.00.00.01.05.3F.15.B8.13.88.26.ED.67.27.47.7F.5F (19)   55.60
[20:42:58][D][ble_adv:075]:     - 0x20CA:0B.00.00.00.00.01.05.57.13.CE.13.88.3E.ED.67.27.47.7F.5F (19)    50.70
[20:52:48][D][ble_adv:075]:     - 0x20CA:0B.00.00.00.00.01.05.83.14.FA.13.88.D9.ED.67.27.47.7F.5F (19)      53.70
[20:59:21][D][ble_adv:075]:     - 0x20CA:0B.00.00.00.00.01.05.BF.15.27.13.88.39.ED.67.27.47.7F.5F (19)     5415
ED.67.27.47.7F.5F是蓝牙MAC,0x20CA也不是MAC地址后两位,实在不一样,(19)后面是我看到的公斤数,转换发现5525---1595,两位对应千克数,cpp也不知道怎么修改了,还请指教。
发表于 2022-10-9 23:03:14 来自手机 | 显示全部楼层
回复标记下有空搞搞
智能家居&单板滑雪痴迷爱好者
 楼主| 发表于 2023-5-10 10:04:29 | 显示全部楼层
这个是logs:
提示payload has wrong size (6)!,你得先用on_ble_advertise把体重秤广播的数据打印出来,看看到底是什么内容,然后再根据实际情况修改代码
发表于 2023-5-10 14:32:14 | 显示全部楼层
XCray 发表于 2023-5-10 10:04
提示payload has wrong size (6)!,你得先用on_ble_advertise把体重秤广播的数据打印出来,看看到底是什 ...
感谢大佬,我后面回去再试试。不过我刚好这两天逆向好轻APP了,也算是解决了同步的问题
发表于 2025-5-13 22:25:16 | 显示全部楼层
大佬  我这边信息是空的   不知道为啥
[22:24:42][D][ble_adv:031]: New BLE device
[22:24:42][D][ble_adv:032]:   address: A4:C1:38:CA:BB:1A
[22:24:42][D][ble_adv:033]:   name: QN-Scale
[22:24:42][D][ble_adv:034]:   Advertised service UUIDs:
[22:24:42][D][ble_adv:036]:     - 0xFFE0
[22:24:42][D][ble_adv:038]:   Advertised service data:
[22:24:42][D][ble_adv:042]:   Advertised manufacturer data:
[22:24:42][D][ble_adv:044]:     - 0xFFFF: (length 11)
发表于 2025-5-14 08:56:24 | 显示全部楼层
441340677 发表于 2025-5-13 22:25
大佬  我这边信息是空的   不知道为啥
解决了  忘记修改format_hex_pretty(data.data).c_str())  这个了
GMT+8, 2025-9-19 08:48 , Processed in 1.290891 second(s), 13 queries , MemCached On.
