查看: 6554|回复: 5
[技术探讨] cnk700i大佬插件havcs探讨
发表于 2021-8-21 19:07:29 | 显示全部楼层 |阅读模式
首先还是比较感谢大佬的开发,让小度、天猫精灵这些可以顺利接入HASS目前刚刚升级了Home Assistant 2021.8.6,使用的是小度平台,授权都正常,但是发现不了设备(只有一个小米WIFI插座),日志里面提示401,是不是大佬的插件和新版本不兼容,上个日志和配置大家帮忙看看
日志
2021-08-21 18:47:22 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration havcs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-08-21 18:47:22 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-08-21 18:47:28 INFO (MainThread) [custom_components.havcs] [init] havcs enable "http mode"
2021-08-21 18:47:28 DEBUG (MainThread) [custom_components.havcs] [init] havcs only run in http mode, skip mqtt initialization
2021-08-21 18:47:28 DEBUG (MainThread) [custom_components.havcs] [init] ha_url = https://localhost:8123, base_url = https://localhost:8123
2021-08-21 18:47:28 INFO (MainThread) [custom_components.havcs] [init] havcs initialization finished.
2021-08-21 18:47:32 INFO (MainThread) [custom_components.havcs] loading settings from file
2021-08-21 18:47:32 DEBUG (MainThread) [custom_components.havcs] [post-task] load new platform entry set()
2021-08-21 18:47:32 DEBUG (MainThread) [custom_components.havcs] [post-task] remove old platform entry set()
2021-08-21 18:47:32 INFO (MainThread) [custom_components.havcs] [post-task] import havcs.dueros
2021-08-21 18:47:32 INFO (MainThread) [custom_components.havcs] loading device info from file
2021-08-21 18:47:32 DEBUG (MainThread) [custom_components.havcs.http] [http] check accessibility from local, base_url = https://localhost:8123
2021-08-21 18:47:32 INFO (MainThread) [custom_components.havcs] [service] ------------dueros 平台加载设备信息------------
[{'device_id': 'havcs.switch01', 'entity_id': ['switch.cha_zuo'], 'type': 'switch', 'name': 'xiaomi', 'zone': 'Bedroom', 'properties': [{'entity_id': 'switch.cha_zuo', 'attribute': 'power_state'}], 'actions': ['turn_on', 'turn_off']}]
2021-08-21 18:47:32 DEBUG (MainThread) [custom_components.havcs.http] [http][check] aouth service is running: url = https://localhost:8123/havcs/auth/authorize, status = 401
2021-08-21 18:47:35 ERROR (MainThread) [custom_components.hacs] tellerbop/havistapool - Repository is archived.
再来个配置
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
  ssl_certificate: /home/pi/ssl_keys/xx.xxx.xxx.pem
  ssl_key: /home/pi/ssl_keys/xx.xxx.xxx.key
  login_attempts_threshold: 10
  ip_ban_enabled: true
  use_x_forwarded_for: true
  trusted_proxies:
    - 117.185.18.0/24
    - 127.0.0.1
    - ::1
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
homeassistant:
  latitude: xxxxx
  longitude: xxxx
  elevation: 315
  unit_system: metric
  currency: CNY
  time_zone: "Asia/Shanghai"
  external_url: "https://xx.xxx.xxx:5001"
havcs:
  platform:
    - dueros
  http:
    clients:
      duerosxxx:  xxxxxx
      aligenie_ignore: ignore
    expire_in_hours: 24
  device_config: ui
logger:
  default: error
  logs:
    custom_components.havcs: debug
3万
发表于 2021-8-21 21:33:11 | 显示全部楼层
这个我也遇到过,去年时升级到解决嵌套问题后的版本,我用小度接入的就出现不能发现设备的问题。后来发现注释掉一条规则过滤的语句就正常了。
前段时间升级了最新版本havcs,还是一样的,当时在作者QQ群中也说了,但好像其他人并没有这个情况,而且论坛中这么久了,快一年了,也从无人提出过同样问题。一直怀疑是我的设置有问题。
 楼主| 发表于 2021-8-22 08:21:53 | 显示全部楼层
dscao 发表于 2021-8-21 21:33
这个我也遇到过,去年时升级到解决嵌套问题后的版本,我用小度接入的就出现不能发现设备的问题。后来发现注 ...
你的现在正常还是
3万
发表于 2021-8-22 08:46:00 | 显示全部楼层
a937287837 发表于 2021-8-22 08:21
你的现在正常还是
每次更新了都要注释掉两句就正常。最新版修改后的,你可以试一下。
havcs.zip
1.85 MB, 下载次数: 200
 楼主| 发表于 2021-8-22 09:34:35 | 显示全部楼层
用了你的配置果然可以了,每次都要注释哪两句呀
发表于 2021-8-23 16:26:34 | 显示全部楼层
按你的方法,困扰了我快一个月的问题总算解决了,
感谢感谢!!
也是和楼主一样的疑问,是注释了哪两行实现的?
GMT+8, 2026-1-17 10:06 , Processed in 0.382483 second(s), 14 queries , MemCached On.
