查看: 28964|回复: 44
挂墙终端Dashboard|Floorplan3D室内动态图|Homekit|测试展示大集锦
hugo
发表于 2017-10-9 01:56:28 | 显示全部楼层 |阅读模式
东西比较乱,有些融合了floorplan,也有homekit,将就看看,就是给大家多点思路参考。
home assistant版本:0.54
appdaemon版本:2.1.9
home assistant 平台:树莓派3
dashboard测试设备:ipad mini2,小米平板2
参与人数 2金钱 +11 收起 理由
jyz_0501 + 1 膜拜大神!
+ 10 效果非常好,谢谢分享!
发表于 2017-10-13 09:48:36 | 显示全部楼层
这个真是牛,,看来我还有很长的路要走!
发表于 2017-10-14 18:29:41 | 显示全部楼层
这好帖子却没被人发现呢
发表于 2017-10-14 19:31:59 来自手机 | 显示全部楼层
厉害啊!!!
发表于 2017-10-17 23:29:34 | 显示全部楼层
這這這...必須學習啊!!!
介面很漂亮!!
发表于 2017-10-26 10:43:25 | 显示全部楼层
楼主牛逼
发表于 2017-10-31 12:56:22 | 显示全部楼层
楼主应该写个教程,我按照frank的教程还是没搞懂
hugo
 楼主| 发表于 2017-11-1 16:05:56 | 显示全部楼层
好,抽空写个,你是那里没搞懂。。可以更加针对性跟你交流
发表于 2017-11-2 09:38:23 | 显示全部楼层
按理说“Successfully installed appdaemon”应该就是安装成功了吧?
先创建完服务,然后
sudo systemctl daemon-reload
sudo systemctl enable appdaemon.service
sudo systemctl start appdaemon.service
重读、允许、开始服务后
查看status的时候都是active:failed
下面是 启动appdaemon服务后 查看status时显示的内容
pi@raspberrypi:/ $ sudo systemctl start appdaemon.service
pi@raspberrypi:/ $ sudo systemctl status appdaemon.service
● appdaemon.service - AppDaemon
   Loaded: loaded (/etc/systemd/system/appdaemon.service; enabled)
   Active: failed (Result: exit-code) since Thu 2017-11-02 10:05:50 CST; 3s ago
  Process: 18590 ExecStart=/usr/local/bin/appdaemon -c /home/pi/appdaemon/conf (code=exited, status=1/FAILURE)
Main PID: 18590 (code=exited, status=1/FAILURE)
Nov 02 10:05:50 raspberrypi appdaemon[18590]: working_set = WorkingSet._build_master()
Nov 02 10:05:50 raspberrypi appdaemon[18590]: File "/usr/lib/python3/dist-packages/pkg_resources.py", line 449, in _build_master
Nov 02 10:05:50 raspberrypi appdaemon[18590]: ws.require(__requires__)
Nov 02 10:05:50 raspberrypi appdaemon[18590]: File "/usr/lib/python3/dist-packages/pkg_resources.py", line 745, in require
Nov 02 10:05:50 raspberrypi appdaemon[18590]: needed = self.resolve(parse_requirements(requirements))
Nov 02 10:05:50 raspberrypi appdaemon[18590]: File "/usr/lib/python3/dist-packages/pkg_resources.py", line 639, in resolve
Nov 02 10:05:50 raspberrypi appdaemon[18590]: raise DistributionNotFound(req)
Nov 02 10:05:50 raspberrypi appdaemon[18590]: pkg_resources.DistributionNotFound: MarkupSafe>=0.23
Nov 02 10:05:50 raspberrypi systemd[1]: appdaemon.service: main process exited, code=exited, status=1/FAILURE
Nov 02 10:05:50 raspberrypi systemd[1]: Unit appdaemon.service entered failed state.
hugo
 楼主| 发表于 2017-11-3 00:19:02 | 显示全部楼层
先创建完服务,然后
conf的设置呢,这下面不是说依赖包没找到么
GMT+8, 2025-12-29 13:25 , Processed in 0.092230 second(s), 15 queries , MemCached On.
