查看: 10239|回复: 4
[基础教程] 新版template如何写多个传感器呀
发表于 2021-7-28 20:33:23 | 显示全部楼层 |阅读模式
template:
  - sensor:
    - name: airhumidifier_humidity
      friendly_name: '环境湿度'
      device_class: humidity
      value_template: '{{ states.fan.xiaomi_air_humidifier.attributes.humidity }}'
      unit_of_measurement: '%'
  - sensor:
    - name: airhumidifier_temperature
      friendly_name: '环境温度'
      value_template: '{{ states.fan.xiaomi_air_humidifier.attributes.temperature }}'
  - sensor:
    - name: airhumidifier_target_humidity
      friendly_name: Target humidity
      value_template: '{{ states.fan.xiaomi_air_humidifier.attributes.target_humidity }}'
      icon_template: mdi:water-percent
  - switches:
    - name: xiaomi_airpurifier_buzzer
      friendly_name: "提示声"
      value_template: "{{ is_state_attr('fan.xiaomi_air_humidifier', 'buzzer', True) }}"
      turn_on:
        service: xiaomi_miio_airpurifier.fan_set_buzzer_on
        data:
          entity_id: fan.xiaomi_air_humidifier
      turn_off:
        service: xiaomi_miio_airpurifier.fan_set_buzzer_off
        data:
      icon_template: "mdi:volume-off"
  - binary_sensor:
    - name: xiaomi_humidifier_nowater
      value_template: >
        {{ is_state('states.fan.xiaomi_air_humidifier.attributes.no_water', 'True') }}
为什么不能识别呀,是哪里写错了吗
发表于 2021-7-29 14:13:34 | 显示全部楼层
- sensor:
    - name: solar_elevation_angle
      unique_id: sensor.solar_elevation_angle
      icon: mdi:arrow-up-bold
      unit_of_measurement: '度'
      state: '{% if states.sun.sun %} {{ states.sun.sun.attributes.elevation }} {% endif %}'
    - name: solar_azimuth_angle
      icon: mdi:arrow-right-bold
      unique_id: sensor.solar_azimuth_angle
      state: "{% if states.sun.sun %} {{ states.sun.sun.attributes.azimuth }} {% endif %}"
发表于 2021-7-29 14:26:13 | 显示全部楼层
官网写的挺清楚的,建议先把list列表和dict字典概念搞清楚了再去玩配置,无论是yaml和json都是无法逃避的基础
 楼主| 发表于 2021-7-29 15:00:41 | 显示全部楼层
blindlight 发表于 2021-7-29 14:26
官网写的挺清楚的,建议先把list列表和dict字典概念搞清楚了再去玩配置,无论是yaml和json都是无法逃避的基 ...
我改好了,原来现在不能用value_template了,用state就行
 楼主| 发表于 2021-7-29 15:01:45 | 显示全部楼层
xuyang 发表于 2021-7-29 14:13
- sensor:
谢谢大佬,我学会了
GMT+8, 2025-12-29 00:18 , Processed in 1.295009 second(s), 9 queries , MemCached On.
