查看: 16152|回复: 7
装完hassbian,电脑可进入pi:8123界面,如何安装homebridge?
发表于 2017-10-8 21:58:28 | 显示全部楼层 |阅读模式
我也就刚刚安装完毕hassbian,用电脑进入pi:8123界面,接下来就不知道怎么安装homebridge?我手头有broadlink sp mini的wifi插座和一个海康威视萤石云C2W的wifi监控摄像头,不知道怎么接入?各位大神有空教下我哈,谢谢!还有,每次通过xshell写sodu命令让树莓派3b链接无线wifi,然后reboot了,反复检查ssid和psk确认无误,可是每次都是失败的!!!明天附图给大家帮忙看看
发表于 2017-10-9 13:42:13 | 显示全部楼层
https://post.smzdm.com/p/594463/?nozhiyou
看这个页面,上面有提示让你如何装homebridge
Freddy.
最佳新人卓越贡献
发表于 2017-10-13 16:44:28 | 显示全部楼层
论坛一大把安装教程,请善用搜索!
发表于 2017-10-21 17:00:37 | 显示全部楼层
starting version 3.2.2
[ADD-ON] Ensuring old PID files are absent
[ADD-ON] Ensuring D-Bus unique ID exists
[ADD-ON] Starting D-Bus daemon
[ADD-ON] Starting Avahi daemon
Found user 'avahi' (UID 86) and group 'avahi' (GID 86).
Successfully dropped root privileges.
avahi-daemon 0.6.32 starting up.
WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Successfully called chroot().
Successfully dropped remaining capabilities.
Loading service file /services/sftp-ssh.service.
Loading service file /services/ssh.service.
*** WARNING: Detected another IPv4 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
Joining mDNS multicast group on interface hassio.IPv4 with address 172.30.32.1.
New relevant interface hassio.IPv4 for mDNS.
Joining mDNS multicast group on interface docker0.IPv4 with address 172.17.0.1.
New relevant interface docker0.IPv4 for mDNS.
Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.31.111.
New relevant interface eth0.IPv4 for mDNS.
Network interface enumeration completed.
Registering new address record for fe80::9034:b2ff:fe09:776 on vethc05f2a1.*.
Registering new address record for fe80::3090:29ff:fe8c:d9fb on veth9165183.*.
Registering new address record for fe80::ac9a:42ff:feb8:806d on veth509278e.*.
Registering new address record for fe80::dc2b:e5ff:fe3e:1c81 on vethab6b56e.*.
Registering new address record for fe80::42:20ff:fea4:3e8c on hassio.*.
Registering new address record for 172.30.32.1 on hassio.IPv4.
Registering new address record for fe80::42:d2ff:fe99:450a on docker0.*.
Registering new address record for 172.17.0.1 on docker0.IPv4.
Registering new address record for fe80::ee90:1208:ae0c:be51 on eth0.*.
Registering new address record for 192.168.31.111 on eth0.IPv4.
Server startup complete. Host name is hassio.local. Local service cookie is 2566166568.
[ADD-ON] Applying HAP NodeJS IPV6 HOTFIX
patching file /usr/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js
[ADD-ON] Starting Homebridge
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat? ... =DNSServiceRegister>
[10/21/2017, 1:56:31 AM] Loaded plugin: homebridge-homeassistant
[10/21/2017, 1:56:31 AM] Registering platform 'homebridge-homeassistant.HomeAssistant'
[10/21/2017, 1:56:31 AM] ---
[10/21/2017, 1:56:31 AM] There was a problem reading your config.json file.
[10/21/2017, 1:56:31 AM] Please try pasting your config.json file here to validate it: http://jsonlint.com
/usr/lib/node_modules/homebridge/lib/server.js:197
    throw err;
SyntaxError: Unexpected token / in JSON at position 71
    at JSON.parse (<anonymous>)
    at Server._loadConfig (/usr/lib/node_modules/homebridge/lib/server.js:191:19)
    at new Server (/usr/lib/node_modules/homebridge/lib/server.js:52:38)
    at module.exports (/usr/lib/node_modules/homebridge/lib/cli.js:26:16)
    at Object.<anonymous> (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (module.js:571:32)
    at Object.Module._extensions..js (module.js:580:10)
    at Module.load (module.js:488:32)
    at tryModuleLoad (module.js:447:12)
    at Function.Module._load (module.js:439:3)
发表于 2017-10-21 17:01:54 | 显示全部楼层
[ADD-ON] Ensuring D-Bus unique ID  ...
请问这个是出现什么错误了啊
发表于 2017-10-22 18:58:35 | 显示全部楼层
二楼正解
发表于 2017-11-6 09:30:11 | 显示全部楼层
找 addon,添加源后就可以了,网上教程很多,先搜索再来问比较好
hbrl 手机认证
发表于 2025-2-24 22:56:32 | 显示全部楼层
请教一下版主:s905l3a盒子冬瓜haos上面怎样安装Homebridge?目的是需要安装Homebridge的apple TV enhanced插件。
GMT+8, 2026-1-15 10:15 , Processed in 1.669546 second(s), 14 queries , MemCached On.
