查看: 14564|回复: 5
[技术探讨] 求助!zigbee2mqtt 自定义设备接入
发表于 2021-7-23 01:37:54 | 显示全部楼层 |阅读模式
闲置的控客zigbee门磁打算接入zigbee2mqtt,官网的文档也写了支持
zigbee2mqtt可以匹配,但是不支持,哪位大神帮忙解决下。感谢
zigbee2mqtt日志
尝试用了官网写的接入方式,但是接入不了
发表于 2021-7-23 02:06:21 | 显示全部楼层
按官方示例自己改配置。
我不生产技术,我只是技术的搬运工。
 楼主| 发表于 2021-7-23 13:26:48 | 显示全部楼层
zxyny1989 发表于 2021-7-23 02:06
按官方示例自己改配置。
按照官方文档修改了一个,不行啊
const fz = require('zigbee-herdsman-converters/converters/fromZigbee');
const tz = require('zigbee-herdsman-converters/converters/toZigbee');
const exposes = require('zigbee-herdsman-converters/lib/exposes');
const reporting = require('zigbee-herdsman-converters/lib/reporting');
const extend = require('zigbee-herdsman-converters/lib/extend');
const e = exposes.presets;
const ea = exposes.access;
const definition = {
    zigbeeModel: ['ZHA-OccupancySen'], // The model ID from: Device with modelID 'lumi.sens' is not supported.
    model: 'diy', // Vendor model number, look on the device for a model number
    vendor: 'diy', // Vendor of the device (only used for documentation and startup logging)
    description: 'Contact sensor', // Description of the device, copy from vendor site. (only used for documentation and startup logging)
    fromZigbee: [fz.ias_contact_alarm_1, fz.battery], // We will add this later
    toZigbee: [], // Should be empty, unless device can be controlled (e.g. lights, switches).
    exposes: [e.contact(), e.battery_low(), e.tamper(), e.battery()], // Defines what this device exposes, used for e.g. Home Assistant discovery and in the frontend
module.exports = definition;
发表于 2021-7-24 01:09:22 | 显示全部楼层
asdasfhth 发表于 2021-7-23 13:26
按照官方文档修改了一个,不行啊
const fz = require('zigbee-herdsman-converters/converters/fromZigbe ...
那是没改对。这个玩意儿我也折腾好久,目前折腾好了。
我不生产技术,我只是技术的搬运工。
 楼主| 发表于 2021-7-27 00:07:47 | 显示全部楼层
z2m实在是搞不定,我把数据通过nodered转换的,勉强用
 楼主| 发表于 2021-7-27 00:26:03 | 显示全部楼层
麻烦指导下,z2m是怎么处理数据的
GMT+8, 2026-1-10 00:18 , Processed in 1.424616 second(s), 8 queries , MemCached On.
