查看: 10525|回复: 1
[求助] Home Assistant Community Add-ons安装的时候老是会报错
发表于 2021-7-21 16:10:38 | 显示全部楼层 |阅读模式
Home Assistant Community Add-ons安装的时候老是会报错:
这个是网络问题吗?
安装加载项失败
Can't install ghcr.io/hassio-addons/plex/amd64:2.6.2: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2.6.2&fromImage=ghcr.io%2Fhassio-addons%2Fplex%2Famd64: Internal Server Error ("Head "https://ghcr.io/v2/hassio-addons/plex/amd64/manifests/2.6.2": Get "https://ghcr.io/token?scope=repository%3Ahassio-addons%2Fplex%2Famd64%3Apull&service=ghcr.io": read tcp 192.168.26.6:38216->18.140.41.152:443: read: connection reset by peer")
发表于 2021-9-1 09:10:36 | 显示全部楼层
这是访问不到ghcr.io的原因,要翻墙
GMT+8, 2025-12-22 09:50 , Processed in 0.220342 second(s), 12 queries , MemCached On.
