查看: 13293|回复: 15
[求助] 大神帮看看装了hacs就一直跳这个错误,但不影响使用
发表于 2021-7-20 11:19:31 | 显示全部楼层 |阅读模式
ESXI安装的haos_ova-6.1.ova
然后装了HACS就显示下面错误
2021-07-20 10:35:40 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-20 10:35:50 ERROR (MainThread) [custom_components.hacs] thomasloven/lovelace-gap-card - Repository is archived.
2021-07-20 10:35:50 ERROR (MainThread) [custom_components.hacs] thomasloven/lovelace-gui-sandbox - Repository is archived.
2021-07-20 10:35:50 ERROR (MainThread) [custom_components.hacs] thomasloven/lovelace-dummy-entity-row - Repository is archived.
2021-07-20 10:35:50 ERROR (MainThread) [custom_components.hacs] troykelly/hacs-amberelectric - Repository is archived.
2021-07-20 10:35:50 ERROR (MainThread) [custom_components.hacs] mammuth/ha-fritzbox-tools - Repository is archived.
2021-07-20 10:35:50 ERROR (MainThread) [custom_components.hacs] bieniu/ha-airly - Repository is archived.
然后多出2个新库
发表于 2021-7-20 16:24:00 | 显示全部楼层
没什么问题
发表于 2021-7-21 00:32:10 | 显示全部楼层
正常情况。
我不生产技术,我只是技术的搬运工。
 楼主| 发表于 2021-7-21 12:01:22 | 显示全部楼层
每次重启都跳这个报警,正常的?
 楼主| 发表于 2021-7-21 12:16:09 | 显示全部楼层
每次重启都跳这个报警,正常的?2个新的存储库 重启也会再出来
另外有时候只有Official add-ons  没有Home Assistant Community Add-ons
添加https://addons.community/ 报错 Invalid Add-on repository!
佑桑
发表于 2021-7-21 13:18:51 | 显示全部楼层
開發者不玩了, 將元件設定為維讀
lovelace-gap-card 為例 https://github.com/thomasloven/lovelace-gap-card
This repository has been archived by the owner. It is now read-only.
有什麼影響嗎? 沒有, 在被刪除之前你還是可以使用
但是因為不再有人維護, 可能某一天 HA 升級後變為不可用
建議尋找元件的替代方案
 楼主| 发表于 2021-7-21 14:22:51 | 显示全部楼层
開發者不玩了, 將視件設定為只讀
以 lovelace-gap-card 為例 https://github.com/ ...
Home Assistant Community Add-ons安装的时候老是会报错:
这个是网络问题吗?
安装加载项失败
Can't install ghcr.io/hassio-addons/plex/amd64:2.6.2: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2.6.2&fromImage=ghcr.io%2Fhassio-addons%2Fplex%2Famd64: Internal Server Error ("Head "https://ghcr.io/v2/hassio-addons/plex/amd64/manifests/2.6.2": Get "https://ghcr.io/token?scope=repository%3Ahassio-addons%2Fplex%2Famd64%3Apull&service=ghcr.io": read tcp 192.168.26.6:38216->18.140.41.152:443: read: connection reset by peer")
发表于 2021-7-24 13:09:54 | 显示全部楼层
另外有时候只有Official add-ons  没有Ho ...
能装新插件吗?
我也这情况,今天装新插件发现不行了。
我不生产技术,我只是技术的搬运工。
 楼主| 发表于 2021-7-27 11:40:19 | 显示全部楼层
zxyny1989 发表于 2021-7-24 13:09
能装新插件吗?
我也这情况,今天装新插件发现不行了。
是网络的问题,换了一个网络环境 就好了
发表于 2021-7-27 12:27:12 | 显示全部楼层
liomlipkim 发表于 2021-7-27 11:40
是网络的问题,换了一个网络环境 就好了
我改了hosts文件,也好了。
我不生产技术,我只是技术的搬运工。
GMT+8, 2025-12-18 13:14 , Processed in 1.358092 second(s), 16 queries , MemCached On.
