查看: 18604|回复: 10
[技术探讨] 有没有大佬帮忙看下日志的,谢谢!
发表于 2021-7-19 22:37:07 | 显示全部楼层 |阅读模式
自从升级到2021.7.1后,在集成中添加群晖就不行了,始终提示如图
日志如下:
Logger: homeassistant.config_entries
Source: components/synology_dsm/__init__.py:596
First occurred: 22:23:21 (3 occurrences)
Last logged: 22:29:55
Error setting up entry 192.168.1.100 for synology_dsm
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 293, in async_setup
    result = await component.async_setup_entry(hass, self)  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/synology_dsm/__init__.py", line 225, in async_setup_entry
    await api.async_setup()
  File "/usr/src/homeassistant/homeassistant/components/synology_dsm/__init__.py", line 440, in async_setup
    await self.async_update()
  File "/usr/src/homeassistant/homeassistant/components/synology_dsm/__init__.py", line 596, in async_update
    await self._hass.async_add_executor_job(
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
  File "/usr/local/lib/python3.9/site-packages/synology_dsm/synology_dsm.py", line 335, in update
    self._security.update()
  File "/usr/local/lib/python3.9/site-packages/synology_dsm/api/core/security.py", line 16, in update
    raw_data = self._dsm.get(self.API_KEY, "system_get")
  File "/usr/local/lib/python3.9/site-packages/synology_dsm/synology_dsm.py", line 204, in get
    return self._request("GET", api, method, params, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/synology_dsm/synology_dsm.py", line 271, in _request
    raise SynologyDSMAPIErrorException(
synology_dsm.exceptions.SynologyDSMAPIErrorException: {'api': 'SYNO.Core.SecurityScan.Status', 'code': 1300, 'reason': 'Unknown', 'details': None}
谢谢各位了!
智能家居&单板滑雪痴迷爱好者
发表于 2021-7-19 23:14:00 来自手机 | 显示全部楼层
建议仔细阅读文档、不要用root账号(这是大忌)
 楼主| 发表于 2021-7-20 10:32:23 | 显示全部楼层
日志没看清多贴了一条,那条root报错的是我始终搞不定随手试试的。上面报错代码是用一般账户登录的,也还是不行。
智能家居&单板滑雪痴迷爱好者
发表于 2021-7-20 10:57:12 | 显示全部楼层
yinghu183 发表于 2021-7-20 10:32
日志没看清多贴了一条,那条root报错的是我始终搞不定随手试试的。上面报错代码是用一般账户登录的,也还 ...
真正有参考意义的信息只有这个:
建议尝试在群晖上运行安全扫描,看看是否有进一步的提示。
实在不行的话,退回2021.6.6(2021.7.x版本似乎问题比较多,我用的sms组件被很多人发现也无法使用,只好退回了,说不定你碰到的也是这样)。
另外,synodsm组件个人感觉意义不大,我用来用去最后发现只有cpu负荷值得在ha里使用,后来找到了更为简洁的snmp方式,这个组件也就不再用了。供参考
 楼主| 发表于 2021-7-20 11:16:17 | 显示全部楼层
XCray 发表于 2021-7-20 10:57
真正有参考意义的信息只有这个:
谢谢你的解答,我想接入群晖主要是因为之前的群晖摄像头接入方式无效了,据说是集成中接入群晖也可以获得摄像头,所以想试试。实在不行也就算了,nodered上也可以抓群晖里摄像头的图片进行推送,只是看实时图像有些麻烦了。
智能家居&单板滑雪痴迷爱好者
发表于 2021-7-20 18:09:20 | 显示全部楼层
yinghu183 发表于 2021-7-20 11:16
谢谢你的解答,我想接入群晖主要是因为之前的群晖摄像头接入方式无效了,据说是集成中接入群晖也可以获得 ...
摄像头???
我记得这个组件只是把群晖系统信息接入到HA,摄像头是另外一个组件,没注意啥时候合并到一起了。。。
发表于 2021-7-20 18:17:42 | 显示全部楼层
群晖摄像头 为什么不用onvif协议接入呢
 楼主| 发表于 2021-7-20 21:11:35 | 显示全部楼层
 楼主| 发表于 2021-7-20 22:43:00 | 显示全部楼层
查了些资料,摄像头不支持onvif。。。
发表于 2021-7-25 16:48:25 | 显示全部楼层
onvif 从群晖中转接入
GMT+8, 2026-1-19 07:12 , Processed in 0.575360 second(s), 5 queries , MemCached On.
