查看: 4297|回复: 1
[基础教程] 求帮助,麻烦各位大神把把脉,谢谢
发表于 2021-7-18 10:18:46 | 显示全部楼层 |阅读模式
homeassistant@homeassistant-PC:~$ hass
2021-07-18 10:15:42 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Unable to import component: No module named '_sqlite3'
2021-07-18 10:15:43 ERROR (MainThread) [homeassistant.setup] Setup failed for dhcp: Unable to import component: No module named '_sqlite3'
2021-07-18 10:15:43 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: recorder
2021-07-18 10:15:43 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2021-07-18 10:15:43 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: recorder
2021-07-18 10:15:43 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not set up all dependencies.
2021-07-18 10:15:44 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: dhcp, history, logbook
2021-07-18 10:15:44 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
智能家居&单板滑雪痴迷爱好者
发表于 2021-7-18 11:00:03 | 显示全部楼层
没安装好?
建议先尝试hassos或者容器方式,熟悉了之后如果还有需求再尝试单独运行core
参考:
https://www.home-assistant.io/docs/installation/
GMT+8, 2025-12-29 00:17 , Processed in 0.709780 second(s), 18 queries , MemCached On.
