查看: 9652|回复: 4
[求助] homeassistant的图形UI界面添加集成,部分无法添加
发表于 2021-7-16 11:20:23 | 显示全部楼层 |阅读模式
homeassistant的图形UI界面添加集成,部分无法添加,安装方式是树莓派4b的python3.8.6虚拟环境安装的homeassistant2021.7.2版本,发现里面有很多集成都无法安装,只有一小部分集成可以安装,无法安装的界面提示:无法加载配置向导
智能家居&单板滑雪痴迷爱好者
发表于 2021-7-16 11:44:23 | 显示全部楼层
看日志,看日志,看日志
发表于 2021-7-16 13:32:37 | 显示全部楼层
XCray 发表于 2021-7-16 11:44
看日志,看日志,看日志
日志:你猜?
 楼主| 发表于 2021-7-16 14:53:03 | 显示全部楼层
看日志,看日志,看日志
超级版主们  你们好:我的日志是这样的:
2021-07-16 14:46:38 ERROR (SyncWorker_5) [homeassistant.loader] Error parsing manifest.json file at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/components/met_eireann/manifest.json: 'gb2312' codec can't decode byte 0xc3 in position 44: illegal multibyte sequence
2021-07-16 14:46:38 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [2938440000] Error handling message: Unknown error
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/components/websocket_api/decorators.py", line 25, in _handle_async_response
await func(hass, connection, msg)
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/components/frontend/__init__.py", line 691, in websocket_get_translations
resources = await async_get_translations(
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/translation.py", line 311, in async_get_translations
cached = await cache.async_fetch(language, category, components)
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/translation.py", line 221, in async_fetch
await self._async_load(language, components_to_load)
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/translation.py", line 236, in _async_load
for translation_strings in await asyncio.gather(
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/translation.py", line 156, in async_get_component_strings
await gather_with_concurrency(
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/util/async_.py", line 170, in gather_with_concurrency
return await gather(
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/util/async_.py", line 168, in sem_task
return await task
这要怎么解决呢??
智能家居&单板滑雪痴迷爱好者
发表于 2021-7-16 16:44:27 | 显示全部楼层
fibonaaci 发表于 2021-7-16 14:53
超级版主们  你们好:我的日志是这样的:
2021-07-16 14:46:38 ERROR (SyncWorker_5) [homeassistant.loa ...
这是什么组件啊?原谅我的孤陋寡闻,从来没听说过。。。
看这句话:
似乎是中文编码的问题。
没用过这个组件,也不知道你具体的环境,日志里也就这句可能有参考意义。
你说的大部分集成都无法安装,日志里是不是还有其他有价值的信息?
总之,解决问题,日志是非常重要的一个分析手段,当然,不可能是可以解决一切问题的手段。
GMT+8, 2025-12-22 15:13 , Processed in 1.845716 second(s), 12 queries , MemCached On.
