查看: 12165|回复: 0
[求助] 米家飞利浦灯能识别状态不能控制故障
发表于 2021-7-15 00:46:12 | 显示全部楼层 |阅读模式
在某次Home Assistant Core更新后出现一个问题
家里所有米家飞利浦吸顶灯在ha里面能识别到状态不能控制,
进入配置》集成里面把Xiaomi Miio下面的设备都删掉,然后重启ha即可恢复,
但是再次重启ha还是会出现这个故障,有没有兄弟遇到过这个问题或者知道怎么解决吗?
Logger: homeassistant.config_entries
Source: components/xiaomi_miio/__init__.py:180
First occurred: 02:27:31 (5 occurrences)
Last logged: 02:27:31
Error unloading entry 主卧灯40w for xiaomi_miio
Error unloading entry 餐厅灯40w for xiaomi_miio
Error unloading entry 次卧灯28w for xiaomi_miio
Error unloading entry 客厅灯80w for xiaomi_miio
Error unloading entry 客卧灯28w for xiaomi_miio
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 432, in async_unload
    result = await component.async_unload_entry(hass, self)  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/xiaomi_miio/__init__.py", line 180, in async_unload_entry
    hass.data[DOMAIN].pop(config_entry.entry_id)
KeyError: 'dfa1e586aaa5cd205a5f047b3b733a7d'
GMT+8, 2025-12-22 15:14 , Processed in 0.302635 second(s), 7 queries , MemCached On.
