楼主: involute
[插件集成] 让你的HomePod可以TTS?没有那么多麻烦
发表于 2021-7-31 05:56:14 来自手机 | 显示全部楼层
Traceback (most recent call last):   File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 169, in _new_conn     conn = connection.create_connection(   File "/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py", line 96, in create_connection     raise err   File "/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py", line 86, in create_connection     sock.connect(sa) TimeoutError: [Errno 110] Operation timed out  During handling of the above exception, another exception occurred:  Traceback (most recent call last):   File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 699, in urlopen     httplib_response = self._make_request(   File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 382, in _make_request     self._validate_conn(conn)   File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 1010, in _validate_conn     conn.connect()   File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 353, in connect     conn = self._new_conn()   File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 181, in _new_conn     raise NewConnectionError( urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7f5b245b2f40>: Failed to establish a new connection: [Errno 110] Operation timed out  During handling of the above exception, another exception occurred:  Traceback (most recent call last):   File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 439, in send     resp = conn.urlopen(   File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 755, in urlopen     retries = retries.increment(   File "/usr/local/lib/python3.9/site-packages/urllib3/util/retry.py", line 574, in increment     raise MaxRetryError(_pool, url, error or ResponseError(cause)) urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='translate.google.com', port=443): Max retries exceeded with url: /_/TranslateWebserverUi/data/batchexecute (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f5b245b2f40>: Failed to establish a new connection: [Errno 110] Operation timed out'))  During handling of the above exception, another exception occurred:  Traceback (most recent call last):   File "/usr/local/lib/python3.9/site-packages/gtts/tts.py", line 264, in write_to_fp     r = s.send(request=pr,   File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 655, in send     r = adapter.send(request, **kwargs)   File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 516, in send     raise ConnectionError(e, request=request) requests.exceptions.ConnectionError: HTTPSConnectionPool(host='translate.google.com', port=443): Max retries exceeded with url: /_/TranslateWebserverUi/data/batchexecute (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f5b245b2f40>: Failed to establish a new connection: [Errno 110] Operation timed out'))  During handling of the above exception, another exception occurred:  Traceback (most recent call last):   File "/usr/src/homeassistant/homeassistant/components/google_translate/tts.py", line 133, in get_tts_audio     tts.write_to_fp(mp3_data)   File "/usr/local/lib/python3.9/site-packages/gtts/tts.py", line 280, in write_to_fp     raise gTTSError(tts=self) gtts.tts.gTTSError: Failed to connect. Probable cause: Unknown
发表于 2021-7-31 06:41:55 来自手机 | 显示全部楼层
我发现之前是我没装百度tts(谷歌不能用)
发表于 2021-7-31 06:42:58 来自手机 | 显示全部楼层
Logger: custom_components.apple_airplayer.device_manager Source: custom_components/apple_airplayer/device_manager.py:105  Integration: Apple AirPlayer (documentation, issues)  First occurred: 06:40:31 (5 occurrences)  Last logged: 06:41:05  Exception raised in async_stream_file, RTSP/1.0 method ANNOUNCE failed with code 400: Bad Request 可这是什么错误呢
 楼主| 发表于 2021-7-31 14:38:28 | 显示全部楼层
Higashi39 发表于 2021-7-31 06:42
Logger: custom_components.apple_airplayer.device_manager Source: custom_components/apple_airplayer/d ...
你是啥回放设备?HA版本是多少?
发表于 2021-7-31 16:25:09 | 显示全部楼层
involute 发表于 2021-7-31 14:38
你是啥回放设备?HA版本是多少?
HomePod mini
HA版本Home Assistant 2021.7.4
 楼主| 发表于 2021-7-31 20:04:20 | 显示全部楼层
Higashi39 发表于 2021-7-31 16:25
HomePod mini
回去阅读顶楼中标红的重要事项3
发表于 2021-7-31 21:55:13 | 显示全部楼层
留个名先,谢谢
发表于 2021-8-1 03:04:30 | 显示全部楼层
involute 发表于 2021-7-31 20:04
回去阅读顶楼中标红的重要事项3
这样啊,我想着没崩溃,一开始感觉不是
发表于 2021-8-2 09:35:17 | 显示全部楼层
CORE7.4也是一播放整个HA就崩溃重启,暂时先不用了,等更新
发表于 2021-8-3 16:57:30 | 显示全部楼层
感谢楼主分享!
GMT+8, 2025-6-29 12:11 , Processed in 1.449714 second(s), 23 queries .
