楼主: involute
[插件集成] 让你的HomePod可以TTS?没有那么多麻烦
发表于 2021-7-11 16:58:21 | 显示全部楼层
新鲜的2021.7.1,快把我搞服了。。。
bash-5.1# pip list | grep -E 'pyatv|attrs'
attrs                            21.2.0
cattrs                           1.7.1
pyatv                            0.8.1
版本应该都没有问题吧
 楼主| 发表于 2021-7-11 17:12:34 | 显示全部楼层
版本应该都没有问题吧
我给你发了条站内信,你加我QQ吧
发表于 2021-7-11 17:16:24 | 显示全部楼层
感谢 学习一下
发表于 2021-7-11 17:26:48 | 显示全部楼层
hassos 装法不太一样
有没有详细教学
发表于 2021-7-11 17:28:11 | 显示全部楼层
zonglong 发表于 2021-7-10 21:24
Hassos (core  2021.7.x , python3.9.x) 装不起来 ,
ha core 2021.7.1 run Mac (python 3.9.x)   装不起来 ,
有安装成功的是 docker ha core  2021.6.5 (python 3.8.x)
錯誤代碼
  File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 790, in exec_module
  File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
  File "/Users/zonglong/.homeassistant/custom_components/apple_airplayer/config_flow.py", line 5, in <module>
    from .device_manager import DeviceManager
  File "/Users/zonglong/.homeassistant/custom_components/apple_airplayer/device_manager.py", line 9, in <module>
    DeviceModel.AirPortExpress: "AirPort Express",
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/enum.py", line 352, in __getattr__
    raise AttributeError(name) from None
AttributeError: AirPortExpress
找到问题 .
宿主装了 0.8.1,但是 HA 的 pyatv 是装在 .deps/lib/python/site-packages/pyatv
把 .deps/lib/python/site-packages/pyatv 改名就可以了.
参与人数 1金钱 +10 收起 理由
involute + 10 赠人玫瑰,手留余香!
发表于 2021-7-11 23:01:01 | 显示全部楼层
宿主机安装pyatv报错
Complete output from command python setup.py egg_info:
      File "<string>", line 1, in <module>
      File "/tmp/pip-build-H2KzRD/pyatv/setup.py", line 31, in <module>
        long_description=read("README.md"),
      File "/tmp/pip-build-H2KzRD/pyatv/setup.py", line 15, in read
        return Path(join(dirname(__file__), fname)).read_text()
    AttributeError: 'PosixPath' object has no attribute 'read_text'
发表于 2021-7-12 11:36:23 | 显示全部楼层
回头试试,请问HomePod mini行不?
发表于 2021-7-12 17:03:05 | 显示全部楼层
大神啊!我是群晖虚拟机里装的hassos,前期准备工作是需要SSH到群晖吗?
发表于 2021-7-13 09:51:28 | 显示全部楼层
厉害了word楼主!
 楼主| 发表于 2021-7-13 12:39:37 | 显示全部楼层
是ssh到你的hassos
GMT+8, 2025-6-29 11:58 , Processed in 1.689603 second(s), 24 queries .
