查看: 11921|回复: 1
[经验分享] 升级到2021.7后小米多模网关插件提示自动化问题解决
发表于 2021-7-9 12:04:32 | 显示全部楼层 |阅读模式
从作者发布的插件问题里搬运的:
修改以下----
'custom_components/xiaomi_gateway3/device_trigger.py' 'TRIGGER_BASE_SCHEMA' to 'DEVICE_TRIGGER_BASE_SCHEMA'
import voluptuous as vol
-from homeassistant.components.device_automation import TRIGGER_BASE_SCHEMA              #修改前
+from homeassistant.components.device_automation import DEVICE_TRIGGER_BASE_SCHEMA        #修改后
from homeassistant.components.homeassistant.triggers import \
     state as state_trigger
from homeassistant.const import *
@@ -10,7 +10,7 @@
from .core import zigbee
from .sensor import BUTTON
-TRIGGER_SCHEMA = TRIGGER_BASE_SCHEMA.extend(                #修改前
+TRIGGER_SCHEMA = DEVICE_TRIGGER_BASE_SCHEMA.extend(              #修改后
         vol.Required(CONF_TYPE): cv.string,
         vol.Required('action'): cv.string
3万
发表于 2021-7-9 19:35:12 | 显示全部楼层
/AlexxIT/XiaomiGateway3  master 已经修复了,插件作者反应是挺快的。
GMT+8, 2025-12-29 00:17 , Processed in 1.221388 second(s), 4 queries , MemCached On.
