楼主: enjulio
[求助] 群晖反向代理报错400Bad request
发表于 2024-4-15 15:31:31 | 显示全部楼层
支持一下
发表于 2024-12-13 10:51:48 | 显示全部楼层
lvhui985119 发表于 2022-1-20 12:40
1.首先确定反代以后是否出现**400: Bad Request**错误,如出现请看下面。
2.然后再hassos日志里面查看是否 ...
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
请问是加在什么位置,还是说直接扔到最后
我直接扔到最后然后重启配置的时候提示Cannot quick reload all YAML configurations because the configuration is not valid: Invalid config for 'http' at configuration.yaml, line 16: not a valid value 'http->trusted_proxies->0', got 'xxx.xxx.xx.xx/24'
发表于 2025-3-17 09:10:53 | 显示全部楼层
拙舌寡墨 发表于 2024-12-13 10:51
请问是加在什么位置,还是说直接扔到最后
我直接扔到最后然后重启配置的时候提示Cannot quick reload al ...
xxx.xxx.xx.0/24
是ip段,不是具体的IP地址
GMT+8, 2025-12-16 15:41 , Processed in 1.004489 second(s), 5 queries , MemCached On.
