查看: 5588|回复: 4
[求助] 安装HA失败
发表于 2021-7-4 22:58:47 | 显示全部楼层 |阅读模式
root@raspberrypi:/home/pi/supervised-installer# journalctl -xe
-- A start job for unit NetworkManager.service has finished with a failure.
-- The job identifier is 8972 and the job result is failed.
Jul 04 22:57:45 raspberrypi systemd[1]: NetworkManager.service: Service RestartSec=100ms expired,
Jul 04 22:57:45 raspberrypi systemd[1]: NetworkManager.service: Scheduled restart job, restart cou
-- Subject: Automatic restarting of a unit has been scheduled
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- Automatic restarting of the unit NetworkManager.service has been scheduled, as the result for
-- the configured Restart= setting for the unit.
Jul 04 22:57:45 raspberrypi systemd[1]: Stopped Network Manager.
-- Subject: A stop job for unit NetworkManager.service has finished
-- A stop job for unit NetworkManager.service has finished.
-- The job identifier is 9035 and the job result is done.
Jul 04 22:57:45 raspberrypi systemd[1]: NetworkManager.service: Start request repeated too quickly
Jul 04 22:57:45 raspberrypi systemd[1]: NetworkManager.service: Failed with result 'exit-code'.
-- Subject: Unit failed
...skipping...
-- The unit NetworkManager.service has entered the 'failed' state with result 'exit-code'.
Jul 04 22:57:45 raspberrypi systemd[1]: Failed to start Network Manager.
-- Subject: A start job for unit NetworkManager.service has failed
-- The job identifier is 9035 and the job result is failed.
智能家居&单板滑雪痴迷爱好者
发表于 2021-7-4 23:09:22 来自手机 | 显示全部楼层
如果不是linux熟手,不建议采用这种安装方式。推荐docker、hassos。
发表于 2021-7-5 08:12:43 | 显示全部楼层
求助,使用docker安装之后可以可以进入输入密码界面,但是输入账号密码之后提示“Something went wrong loading onboarding, try refreshing”
发表于 2021-7-5 08:41:47 | 显示全部楼层
chaungyu1897 发表于 2021-7-5 08:12
求助,使用docker安装之后可以可以进入输入密码界面,但是输入账号密码之后提示“Something went wrong l ...
对于 homeassistant 的维护与安装,最重要的是学会看日志解决问题
发表于 2021-7-5 09:18:31 | 显示全部楼层
说的有道理,之前在虚拟机上安装啥问题没有,所以这次就有点蒙
GMT+8, 2025-12-22 13:09 , Processed in 1.578575 second(s), 10 queries , MemCached On.
