查看: 15683|回复: 1
[基础教程] N1 python3.9 pip 安装失败
发表于 2021-7-2 22:32:48 | 显示全部楼层 |阅读模式
纯小白,从来没接触过Linux,因为hass提示需要升级到Python3.8,干脆就下载了个Python3.9按照网上教程来安装,但是装完pip始终装不上,用sudo apt install python3-pip 安装后提示安装成功,显示
python3-pip is already the newest version (18.1-5).The following packages were automatically installed and are no longer required:
  apt-file libapt-pkg-perl libexporter-tiny-perl liblist-moreutils-perl
  libregexp-assemble-perl
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 96 not upgraded.
但是如果用pip3 -V 显示
raceback (most recent call last):
  File "/usr/bin/pip3", line 9, in <module>
    from pip._internal import main
ModuleNotFoundError: No module named 'pip'
我是怎么都找不到这个pip文件,python3.9安装的时候并没有自动安装pip,然后我手动Python3 setup.py
提示:Traceback (most recent call last):
  File "<frozen zipimport>", line 520, in _get_decompress_func
ModuleNotFoundError: No module named 'zlib'
  File "<frozen zipimport>", line 568, in _get_data
  File "<frozen zipimport>", line 523, in _get_decompress_func
zipimport.ZipImportError: can't decompress data; zlib not available
  File "/root/Python-3.9.6/get-pip.py", line 24312, in <module>
    main()
  File "/root/Python-3.9.6/get-pip.py", line 139, in main
    bootstrap(tmpdir=tmpdir)
  File "/root/Python-3.9.6/get-pip.py", line 115, in bootstrap
    monkeypatch_for_cert(tmpdir)
  File "/root/Python-3.9.6/get-pip.py", line 96, in monkeypatch_for_cert
    from pip._internal.commands.install import InstallCommand
  File "<frozen zipimport>", line 241, in load_module
  File "<frozen zipimport>", line 709, in _get_module_code
  File "<frozen zipimport>", line 570, in _get_data
实在搞不定了,请教各位高手
硬件N1,系统 Armbian Linux 5.3.0-aml-g12
mitu 手机认证
发表于 2021-7-4 16:07:32 | 显示全部楼层
再次make install,操心看错误提示,你的这种情况应该是Python3.9安装出错了。
GMT+8, 2025-12-28 22:20 , Processed in 1.172556 second(s), 10 queries , MemCached On.
