查看: 114462|回复: 240
[新奇玩法] 我也来个电费插件(RN流)-浙江
发表于 2021-6-28 14:20:21 | 显示全部楼层 |阅读模式
1、通过stream抓取国网浙江电力的公众号,有个checkLogin的链接,复制后面的参数填入nr里面设置参数节点,然后再填写你的户号,同步间隔最好一天一次,免的被拉黑。
2、实体在集成里添加Node-RED Companion,没有的自行在HACS里安装
2022.5.20 修复了公众号字段变更引起的问题
                 修改了设置参数节点  params需要抓包checkLogin后面参数解码后再填入
2022.9.20 修复了公众号更新后不可用
UI配置
  - title: 电费
    path: ''
    icon: mdi:lightning-bolt
    badges: []
    cards:
      - type: gauge
        entity: sensor.gong_lu
        needle: true
        severity:
          green: 0
          yellow: 1000
          red: 3000
        min: 0
        unit: ' '
        max: 6000
      - type: grid
        cards:
          - type: entities
            state_color: true
            show_header_toggle: false
            entities:
              - entity: sensor.daily_energy
                type: custom:multiple-entity-row
                secondary_info: last-changed
                icon: mdi:ev-station
                unit: 度
                entities:
                  - entity: sensor.daily_energy_peak
                    unit: false
                  - entity: sensor.daily_energy_offpeak
                    unit: false
              - entity: sensor.daily_energy_cost
                unit: 元
                entities:
                  - entity: sensor.daily_energy_peak_cost
                    unit: false
                  - entity: sensor.daily_energy_offpeak_cost
                    unit: false
              - entity: sensor.dayelectricity
                entities:
                  - attribute: f
                  - attribute: g
              - entity: sensor.dayelectricityprice
                entities:
                  - attribute: daypricef
                  - attribute: daypriceg
              - entity: sensor.monthelectricity
                entities:
                  - attribute: f
                  - attribute: g
              - entity: sensor.monthelectricityprice
                entities:
                  - attribute: monthpricef
                  - attribute: monthpriceg
              - entity: sensor.yearelectricity
              - type: custom:bar-card
                width: 45%
                height: 2em
                decimal: 0
                unit_of_measurement: '%'
                positions:
                  icon: outside
                  indicator: 'off'
                severity:
                  - color: Green
                    to: 25
                  - color: Orange
                    to: 50
                  - color: Red
                    to: 100
                entity_row: true
                entities:
                  - entity: sensor.electricity_first
                  - entity: sensor.electricity_second
                width: 45%
                height: 2em
                decimal: 0
                unit_of_measurement: 度
                positions:
                  icon: outside
                  indicator: 'off'
                severity:
                  - color: '#303435'
                    to: 100
                  - color: '#6d2525'
                    to: 10
                entity_row: true
                entities:
                  - entity: sensor.electricity_thired
        columns: 1
        square: false
      - type: custom:apexcharts-card
        graph_span: 15d
        locale: zh-cn
        all_series_config:
          stroke_width: 2
          opacity: 0.8
          type: line
        header:
          show: true
          title: 用电情况
          show_states: true
          colorize_states: true
        series:
          - entity: sensor.historyelectricity
            data_generator: |
              const data = [];
              entity.attributes.history.map((peak, index) => {
                data.push([new Date(peak.datetime).getTime(), peak.ZXYGZ2]);
              for( var i = 0; i < data.length; i++ ){
                 for( var j = i + 1; j < data.length; j++ ){
                     if(data[i][0] > data[j][0]){
                        const data1 = data[i];
                        data[i] = data[j];
                        data[j] = data1;
              return data;
            data_generator: |
              const data = [];
                data.push([new Date(peak.datetime).getTime(), peak.ZXYGZ4]);
                        data[i] = data[j];
                        data[j] = data1;
              return data;
            data_generator: |
              const data = [];
                data.push([new Date(peak.datetime).getTime(), peak.ZXYGZ]);
                        data[i] = data[j];
                        data[j] = data1;
              return data;
        graph_span: 12month
        locale: zh-cn
        all_series_config:
          stroke_width: 2
          opacity: 0.8
          type: column
          show:
            legend_value: false
            datalabels: true
            as_duration: month
        header:
          show: true
          title: 月度电费
        series:
          - entity: sensor.historyelectricitybill
            data_generator: >-
              return entity.attributes.list.map((peak, index) => { return [new
              Date(peak.recordDate).getTime(), peak.rcvedAmt]; });
        graph_span: 12month
        locale: zh-cn
        all_series_config:
          stroke_width: 2
          opacity: 0.8
          type: column
          show:
            legend_value: false
            datalabels: true
            as_duration: month
        header:
          show: true
          title: 月度耗电
        series:
            unit: 度
            data_generator: >-
              Date(peak.recordDate).getTime(), peak.pq]; });
电费修复.rar
5.04 KB, 下载次数: 499
电费20220920.rar
5.1 KB, 下载次数: 389
参与人数 7金钱 +46 收起 理由
llgxdnn + 5 感谢楼主分享!
sczdlj` + 5 高手,这是高手!
ysst4 + 5 高手,这是高手!
nbasia + 5
h5529 + 1
wbdlwz + 5 感谢楼主分享!
+ 20 感谢楼主分享!
发表于 2021-6-28 14:25:47 来自手机 | 显示全部楼层
太棒了,有福建的吗!
 楼主| 发表于 2021-6-28 14:40:45 | 显示全部楼层
wcm12345 发表于 2021-6-28 14:25
太棒了,有福建的吗!
这个真没有,哈哈 ,福建应该是不同的公众号
发表于 2021-6-28 15:00:58 | 显示全部楼层
安徽的公众号和小程序我都试了,啥也抓不着,或许是我姿势不对。。。
发表于 2021-6-28 16:25:42 | 显示全部楼层
河北的我也没抓到,完全看不懂
fhxu
发表于 2021-6-28 18:49:50 | 显示全部楼层
大佬怎么抓取,来个教程
发表于 2021-6-29 00:38:12 来自手机 | 显示全部楼层
谁能来个广西的
 楼主| 发表于 2021-6-29 08:19:14 | 显示全部楼层
fhxu 发表于 2021-6-28 18:49
大佬怎么抓取,来个教程
抓包也很简单,打开stream点开始,然后打开公众号或者小程序,等你想要的页面加载完后,回到stream停止抓包,然后在历史里面找你想要的http请求,最后就是分析请求返回的json
发表于 2021-6-29 10:10:44 | 显示全部楼层
tangxingjie1991 发表于 2021-6-29 08:19
抓包也很简单,打开stream点开始,然后打开公众号或者小程序,等你想要的页面加载完后,回到stream停止抓 ...
抓包好,但不知道在那个项内,太多。能指点下吗?
发表于 2021-6-29 13:33:37 | 显示全部楼层
GMT+8, 2025-12-13 16:17 , Processed in 0.180129 second(s), 12 queries , MemCached On.
