查看: 10785|回复: 1
[求助] 接小米网关报错,小白求指导
发表于 2017-10-3 22:14:39 | 显示全部楼层 |阅读模式
如题,系统是按囧大Ubuntu安装HomeAssistant教程(ubuntu17.04无坑版),直接配置的xiaomi.yaml,提示缺少文件,需要怎么安装呢?谢谢
2017-10-03 22:03:43 ERROR (Thread-2) [homeassistant.util.package] Unable to install package https://github.com/Danielhiverse ... aomiGateway==0.3.0: Command "/srv/homeassistant/homeassistant_venv/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-1l7ujn6a/pyCrypto/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-7jp9hesk-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/homeassistant_venv/include/site/python3.5/pyCrypto" failed with error code 1 in /tmp/pip-build-1l7ujn6a/pyCrypto/
2017-10-03 22:03:43 ERROR (MainThread) [homeassistant.setup] Not initializing xiaomi because could not install dependency https://github.com/Danielhiverse ... iaomiGateway==0.3.0
2017-10-03 22:03:43 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi: Could not install all requirements.
发表于 2017-10-8 11:14:10 | 显示全部楼层
同样的问题,请教一下大神
GMT+8, 2025-12-16 14:19 , Processed in 0.913527 second(s), 10 queries , MemCached On.
