楼主: jack9603301
[基础教程] HASS集成互联网天气
发表于 2022-2-6 06:18:58 | 显示全部楼层
appkey: <appkey>
改成
appkey: <cheivuehriveurhiveuhievuieuiv>
是这样么?
发表于 2022-2-6 06:38:42 | 显示全部楼层
各种未知数据,
2022-02-06 06:32:24 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_miot_raw which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-06 06:32:24 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration colorfulclouds which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-06 06:32:24 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration HeWeather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-06 06:32:24 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration HeWeather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-06 06:32:24 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration xiaomi_miot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-06 06:32:25 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-02-06 06:32:31 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.shi_shi_ti_gan_wen_du (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:32 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.shi_shi_shi_wai_wen_du (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:33 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.tian_qi_zhuang_tai (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:33 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.feng_su (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:33 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.shi_shi_shi_wai_shi_du (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:33 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.jiang_shui_liang (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:35 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.da_qi_ya (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:35 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.neng_jian_du (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:37 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.feng_li (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:38 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.kong_qi_zhi_liang_zhi_shu (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:38 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.zhu_yao_wu_ran_wu (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:38 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.kong_qi_zhi_liang (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:39 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.pm10 (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:39 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.pm2_5 (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:39 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.shu_gua_du_zhi_shu (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:39 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.xi_che_zhi_shu (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:39 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.chuan_yi_zhi_shu (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:39 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.gan_mou_zhi_shu (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:39 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.yun_dong_zhi_shu (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:39 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.chu_xing_zhi_shu (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:39 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.zi_wai_xian_zhi_shu (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:39 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.feng_xiang (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:40 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.jin_ri_zui_gao_wen_du (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:40 WARNING (MainThread) [async_upnp_client.profiles.profile] Failed subscribing to service: UpnpResponseError('Did not receive HTTP 200 but 500')
2022-02-06 06:32:40 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.jin_ri_zui_di_wen_du (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
2022-02-06 06:32:40 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.jiang_shui_gai_lu (<class 'custom_components.HeWeather。m.sensor.HeWeatherSensor'>) implements device_state_attributes. Please report it to the custom component author.
 楼主| 发表于 2022-3-2 16:23:57 | 显示全部楼层
tiankai 发表于 2022-2-6 06:38
各种未知数据,
我也发现不行了 改天看看
发表于 2022-3-22 11:12:38 | 显示全部楼层
jack9603301 发表于 2022-1-27 18:49
奇怪了,感觉是API接口访问https错误。你确定网络没问题?
网络没问题,这都能上网,也能获取出来一部分气温啥的,pm2.5获取不到
发表于 2022-3-25 16:36:52 | 显示全部楼层
jack9603301 发表于 2022-3-2 16:23
我也发现不行了 改天看看
现在完全不行了,也不报错,直接都不显示了
发表于 2022-3-31 22:07:12 | 显示全部楼层
是的,现在没有天气组件可以用了
 楼主| 发表于 2022-4-2 19:03:59 | 显示全部楼层
www513132003 发表于 2022-3-31 22:07
是的,现在没有天气组件可以用了
是啊 有没有什么新的方案。。
发表于 2022-4-3 17:28:25 | 显示全部楼层
jack9603301 发表于 2022-4-2 19:03
是啊 有没有什么新的方案。。
我又可以了
 楼主| 发表于 2022-4-3 17:30:59 | 显示全部楼层
我才打算剥离掉突然又可以了?确认?
发表于 2022-4-3 17:51:21 | 显示全部楼层
是啊 有没有什么新的方案。。
用彩云天气
GMT+8, 2026-1-18 23:24 , Processed in 0.051921 second(s), 6 queries , MemCached On.
