查看: 13168|回复: 1
[求助] xiaomi_miio_raw接入gosound 16a插座遇到一些问题
发表于 2021-6-16 20:36:25 | 显示全部楼层 |阅读模式
  - platform: xiaomi_miio_raw
    host: 192.168.51.162
    token:
    # Optional and device specific config parameters
    sensor_property: "power"
    sensor_unit: "watt"
switch:
  - platform: template
    switches:
      reshuiqi_switch:
        unique_id: reshuiqi_switch
        value_template: "{{ state_attr('sensor.reshuiqi_props_2'),'on' }}"
        turn_on:
          service: xiaomi_miio_raw.sensor_raw_command
          data:
            entity_id: sensor.reshuiqi_props_2
            method: set_properties
            params:
              - did: on
                siid: 2
                piid: 1
                value: True
        turn_off:
          data:
            params:
              - did: on
                siid: 2
                piid: 1
                value: False
用python miio命令行能够正常开关和获取开关状态,但是lovalace里面打开后直接显示为关闭状态,获取不到开关当前状态,无法关闭开关
猜测可能是没有正确获取到开关状态导致
已经用大佬的miot插件正常接入,想折腾学习一下,希望各位大佬指点指点
发表于 2021-6-16 23:13:22 | 显示全部楼层
前排围观大佬
GMT+8, 2025-11-6 22:07 , Processed in 0.060826 second(s), 6 queries , MemCached On.
