查看: 20857|回复: 4
[技术探讨] 群晖docker安装z2m奇怪的问题,请大佬帮忙看看!
发表于 2021-6-11 10:50:44 | 显示全部楼层 |阅读模式
安装的1.19.1版本的z2m,启动没有问题,但是每过10分钟左右就会显示网关离线,然后容器意外停止,实际网关是在线的能ping通,而且马上启动容器还可以正常启动,过10分钟左右又出现同样问题。网关下只接了一个小米的门磁。
info  2021-06-11 11:20:24: Logging to console and directory: '/app/data/log/2021-06-11.11-20-24'
info  2021-06-11 11:20:27: Starting zigbee2mqtt version 1.9.0 (commit #287f843)
info  2021-06-11 11:20:27: Starting zigbee-herdsman...
info  2021-06-11 11:20:30: zigbee-herdsman started
info  2021-06-11 11:20:30: Coordinator firmware version: '{"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20201010}}'
info  2021-06-11 11:20:31: Currently 0 devices are joined:
warn  2021-06-11 11:20:31: `permit_join` set to  `true` in configuration.yaml.
warn  2021-06-11 11:20:31: Allowing new devices to join.
warn  2021-06-11 11:20:31: Set `permit_join` to `false` once you joined all devices.
info  2021-06-11 11:20:31: Zigbee: allowing new devices to join.
info  2021-06-11 11:20:31: Connecting to MQTT server at mqtt://192.168.1.21:1883
info  2021-06-11 11:20:31: Connected to MQTT server
info  2021-06-11 11:20:31: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
info  2021-06-11 11:20:31: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version":"1.9.0","commit":"287f843","coordinator":{"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20201010}},"log_level":"info","permit_join":true}'
info  2021-06-11 11:20:36: MQTT publish: topic 'zigbee2mqtt/bridge/config/devices', payload '[{"ieeeAddr":"0x00124b00041e239e","type":"Coordinator","networkAddress":0,"friendly_name":"Coordinator","softwareBuildID":"zStack30x","dateCode":"20201010","lastSeen":1623381636385}]'
info  2021-06-11 11:20:36: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"devices","message":[{"ieeeAddr":"0x00124b00041e239e","type":"Coordinator","networkAddress":0,"friendly_name":"Coordinator","softwareBuildID":"zStack30x","dateCode":"20201010","lastSeen":1623381636394}]}'
info  2021-06-11 11:21:01: Starting network scan (includeRoutes 'false')
info  2021-06-11 11:21:01: Network scan finished
info  2021-06-11 11:21:01: MQTT publish: topic 'zigbee2mqtt/bridge/networkmap/raw', payload '{"nodes":[{"ieeeAddr":"0x00124b00041e239e","friendlyName":"Coordinator","type":"Coordinator","networkAddress":0,"failed":[],"lastSeen":null}],"links":[{"source":{"ieeeAddr":"0x00158d000153dc32","networkAddress":56433},"target":{"ieeeAddr":"0x00124b00041e239e","networkAddress":0},"linkquality":70,"depth":1,"routes":[],"sourceIeeeAddr":"0x00158d000153dc32","targetIeeeAddr":"0x00124b00041e239e","sourceNwkAddr":56433,"lqi":70,"relationship":1}]}'
info  2021-06-11 11:21:22: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"groups","message":[]}'
info  2021-06-11 11:21:22: MQTT publish: topic 'zigbee2mqtt/bridge/config/devices', payload '[{"ieeeAddr":"0x00124b00041e239e","type":"Coordinator","networkAddress":0,"friendly_name":"Coordinator","softwareBuildID":"zStack30x","dateCode":"20201010","lastSeen":1623381682163}]'
info  2021-06-11 11:21:22: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"devices","message":[{"ieeeAddr":"0x00124b00041e239e","type":"Coordinator","networkAddress":0,"friendly_name":"Coordinator","softwareBuildID":"zStack30x","dateCode":"20201010","lastSeen":1623381682170}]}'
info  2021-06-11 11:21:22: MQTT publish: topic 'zigbee2mqtt/bridge/config/devices', payload '[{"ieeeAddr":"0x00124b00041e239e","type":"Coordinator","networkAddress":0,"friendly_name":"Coordinator","softwareBuildID":"zStack30x","dateCode":"20201010","lastSeen":1623381682659}]'
info  2021-06-11 11:21:22: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"devices","message":[{"ieeeAddr":"0x00124b00041e239e","type":"Coordinator","networkAddress":0,"friendly_name":"Coordinator","softwareBuildID":"zStack30x","dateCode":"20201010","lastSeen":1623381682664}]}'
info  2021-06-11 11:24:00: MQTT publish: topic 'zigbee2mqtt/bridge/config/devices', payload '[{"ieeeAddr":"0x00124b00041e239e","type":"Coordinator","networkAddress":0,"friendly_name":"Coordinator","softwareBuildID":"zStack30x","dateCode":"20201010","lastSeen":1623381840057}]'
info  2021-06-11 11:24:00: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"devices","message":[{"ieeeAddr":"0x00124b00041e239e","type":"Coordinator","networkAddress":0,"friendly_name":"Coordinator","softwareBuildID":"zStack30x","dateCode":"20201010","lastSeen":1623381840063}]}'
error 2021-06-11 11:30:31: Adapter disconnected, stopping
发表于 2021-6-11 13:53:43 来自手机 | 显示全部楼层
是不是你群暉硬盤休眠了
 楼主| 发表于 2021-6-13 16:28:56 | 显示全部楼层
Sourdough 发表于 2021-6-11 13:53
是不是你群暉硬盤休眠了
休眠都关了啊,而且现在不定期就意外停止
发表于 2021-6-13 18:18:23 来自手机 | 显示全部楼层
caoxi1988 发表于 2021-6-13 16:28
休眠都关了啊,而且现在不定期就意外停止
弄个树莓派试试看看是不是你coordinator的問題
发表于 2021-7-21 15:04:34 | 显示全部楼层
群晖docker没有这么麻烦吧,你用的是哪个z2m镜像啊
GMT+8, 2025-12-29 02:28 , Processed in 0.476690 second(s), 8 queries , MemCached On.
