查看: 31153|回复: 8
[技术探讨] 各位大佬,z2m弄好了,怎么才能显示出来呢?
发表于 2021-6-10 21:01:19 | 显示全部楼层 |阅读模式
环境是群晖docker装的homeassistant和z2m,下边是配置文件。已解决,docker需要装个z2massistant
homeassistant: true
permit_join: true
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://192.168.1.21:1883'
  user: mqtt
  password: mqtt
  client_id: MY_CLIENT_ID
  include_device_information: true
  disable_led: true
serial:
  port: 'tcp://192.168.1.6:6638'
  advanced:
  baudrate: 115200
  rtscts: false
  channel: 15
  pan_id: 6754
  ext_pan_id:
    - 221
    - 221
    - 221
    - 221
    - 221
    - 221
    - 221
    - 221
experimental:
  transmit_power: 20
frontend:
  port: 8080
以下是z2m日志,看日志应该是成功了吧,为什么ha里什么都看不到呢,ha还需要设置什么吗?
info  2021-06-10 12:45:27: Logging to console and directory: '/app/data/log/2021-06-10.12-45-23' filename: log.txt
info  2021-06-10 12:45:27: Starting Zigbee2MQTT version 1.18.3 (commit #f2e39af)
info  2021-06-10 12:45:27: Starting zigbee-herdsman (0.13.92)
info  2021-06-10 12:45:31: zigbee-herdsman started
info  2021-06-10 12:45:31: Coordinator firmware version: '{"meta":{"maintrel":2,"majorrel":2,"minorrel":7,"product":2,"revision":20201010,"transportrev":2},"type":"zStack30x"}'
info  2021-06-10 12:45:31: Set transmit power to '20'
info  2021-06-10 12:45:31: Currently 0 devices are joined:
warn  2021-06-10 12:45:31: `permit_join` set to  `true` in configuration.yaml.
warn  2021-06-10 12:45:31: Allowing new devices to join.
warn  2021-06-10 12:45:31: Set `permit_join` to `false` once you joined all devices.
info  2021-06-10 12:45:31: Zigbee: allowing new devices to join.
info  2021-06-10 12:45:31: Started frontend on port 0.0.0.0:8080
info  2021-06-10 12:45:31: Connecting to MQTT server at mqtt://192.168.1.21:1883
info  2021-06-10 12:45:32: Connected to MQTT server
info  2021-06-10 12:45:32: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
info  2021-06-10 12:45:32: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"f2e39af","coordinator":{"meta":{"maintrel":2,"majorrel":2,"minorrel":7,"product":2,"revision":20201010,"transportrev":2},"type":"zStack30x"},"log_level":"info","network":{"channel":11,"extendedPanID":"0x00124b00041e239e","panID":6754},"permit_join":true,"version":"1.18.3"}'
发表于 2021-6-10 21:04:32 | 显示全部楼层
先配对- -
然后设备的配置看这里
https://www.zigbee2mqtt.io/information/supported_devices.html
 楼主| 发表于 2021-6-10 21:07:58 | 显示全部楼层
sirakawa 发表于 2021-6-10 21:04
先配对- -
然后设备的配置看这里
https://www.zigbee2mqtt.io/information/supported_devices.html ...
我在ha界面里啥都看不到找不到配对按钮啊
发表于 2021-6-11 04:04:05 | 显示全部楼层
zigbee2mqtt是没有配对按钮的,看你的设置permit_join true,所以是一直开放的,只要重置了子设备,如果是兼容的,就会自动加入
 楼主| 发表于 2021-6-11 06:53:00 | 显示全部楼层
firewater 发表于 2021-6-11 04:04
zigbee2mqtt是没有配对按钮的,看你的设置permit_join true,所以是一直开放的,只要重置了子设备,如果是 ...
谢谢大佬,难道homeassistant下没有像hassio下边那种zigbee地图和ui插件吗?docker下的z2m没有管理页面么
发表于 2021-6-12 00:56:15 | 显示全部楼层
caoxi1988 发表于 2021-6-11 06:53
谢谢大佬,难道homeassistant下没有像hassio下边那种zigbee地图和ui插件吗?docker下的z2m没有管理页面么 ...
你说的都有的,在supervisor,addon里面设置
Show in sidebar
Add this add-on to your sidebar
开启,就在边栏里面可以看见了
发表于 2021-6-12 09:51:17 | 显示全部楼层
frontend:
  port: 8080
看你的配置已经启用Z2M的前端了,DOCKER RUN时候映射一下这个端口,然后访问就可以
前端里本身就有配对以及改名删除啥的基本功能
 楼主| 发表于 2021-6-13 16:25:11 | 显示全部楼层
sirakawa 发表于 2021-6-12 09:51
frontend:
  port: 8080
谢谢
发表于 2021-7-21 15:07:33 | 显示全部楼层
GMT+8, 2025-12-29 00:17 , Processed in 1.226202 second(s), 9 queries , MemCached On.
