查看: 8016|回复: 3
[求助] 小米万能遥控器和Aqara空调伴侣miio问题
发表于 2017-9-29 17:03:55 | 显示全部楼层 |阅读模式
2017-09-29 15:53:29 ERROR (Thread-11) [PyXiaomiGateway] Unsupported device found! Please create an issue at https://github.com/Danielhiversen/PyXiaomiGateway/issues and provide the following data: {'cmd': 'read_ack', 'sid': '158d0001d58004', 'short_id': 8746, 'model': 'sensor_switch.aq3', 'data': '{"voltage":3025}'}2017-09-29 15:53:32 ERROR (Thread-7) [homeassistant.util.package] Unable to install package python-miio==0.0.8: Could not find a version that satisfies the requirement python-miio==0.0.8 (from versions: )No matching distribution found for python-miio==0.0.82017-09-29 15:53:32 ERROR (MainThread) [homeassistant.setup] Not initializing switch.chuangmi_ir because could not install dependency python-miio==0.0.82017-09-29 15:53:32 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.chuangmi_ir: Could not install all requirements.2017-09-29 15:53:37 ERROR (Thread-6) [homeassistant.util.package] Unable to install package python-miio==0.0.11: Could not find a version that satisfies the requirement python-miio==0.0.11 (from versions: )No matching distribution found for python-miio==0.0.112017-09-29 15:53:37 ERROR (MainThread) [homeassistant.setup] Not initializing climate.mi_acpartner because could not install dependency python-miio==0.0.112017-09-29 15:53:37 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform climate.mi_acpartner: Could not install all requirements.
这里还有一个Aqara无线开关迷你版不支持
发表于 2017-9-29 18:33:56 | 显示全部楼层
论坛之前的创米遥控器的插件代码已无法在新的 python-mirobo 使用了,等大神更新吧。
 楼主| 发表于 2017-9-29 19:11:25 | 显示全部楼层
lylus 发表于 2017-9-29 18:33
论坛之前的创米遥控器的插件代码已无法在新的 python-mirobo 使用了,等大神更新吧。 ...
Aqara空调伴侣目前也无法使用,和代码也有关系吗
发表于 2017-10-29 17:22:22 | 显示全部楼层
aqara空调伴侣可以接入吗?
GMT+8, 2025-12-25 15:42 , Processed in 0.548007 second(s), 18 queries , MemCached On.
