查看: 15861|回复: 3
求助*!!!!官方最新HASS.IO镜像安装问题
发表于 2021-6-7 10:57:44 | 显示全部楼层 |阅读模式
镜像正常刷入SD,插上树莓派启动一直处于准备页面,查看安装日志显示以下内容20-09-12 12:41:26 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/raspberrypi3-homeassistant:landingpage to homeassistant/raspberrypi3-homeassistant:2021.6.220-09-12 12:41:26 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-homeassistant with tag 2021.6.2.
20-09-12 12:41:27 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:2021.6.2 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.6.2&fromImage=homeassistant%2Fraspberrypi3-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": x509: certificate has expired or is not yet valid: current time 2020-09-12T12:41:27Z is before 2021-04-25T00:00:00Z").
20-09-12 12:41:27 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
 楼主| 发表于 2021-6-7 11:00:48 | 显示全部楼层
看日志是因为时钟不对导致的证书未生效,但是hass.io我不知道怎么改时钟
发表于 2021-8-11 10:52:12 | 显示全部楼层
我也同样问题
发表于 2021-10-7 20:41:29 | 显示全部楼层
我发现我也是现在不能装了????
GMT+8, 2025-12-2 18:23 , Processed in 0.795468 second(s), 8 queries , MemCached On.
