查看: 2331|回复: 3
[求助] 如下报错有无影响,如何解决?
发表于 2021-6-6 19:55:32 | 显示全部楼层 |阅读模式
2021-06-06 19:28:01 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.8/site-packages/zigpy/device.py", line 97, in group_membership_scan
await ep.group_membership_scan()
File "/usr/local/lib/python3.8/site-packages/zigpy/endpoint.py", line 161, in group_membership_scan
groups = {group for group in res[1]}
TypeError: 'Status' object is not iterable
2021-06-06 19:28:33 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:29:04 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:29:09 WARNING (MainThread) [zigpy.zdo] [0x26ac:zdo] Data remains after deserializing ZDO frame
2021-06-06 19:29:19 WARNING (MainThread) [zigpy.device] [0x26ac] Requesting Node Descriptor failed
File "/usr/local/lib/python3.8/site-packages/zigpy/device.py", line 102, in get_node_descriptor
status, _, node_desc = await self.zdo.Node_Desc_req(
File "/usr/local/lib/python3.8/site-packages/zigpy/util.py", line 110, in retry
r = await func()
File "/usr/local/lib/python3.8/site-packages/zigpy/device.py", line 216, in request
raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: [0x26ac:0:0x0002]: Message send failure
2021-06-06 19:29:35 WARNING (MainThread) [zigpy.device] [0x26ac] Failed to discover active endpoints
File "/usr/local/lib/python3.8/site-packages/zigpy/device.py", line 119, in _initialize
status, _, endpoints = await self.zdo.Active_EP_req(
r = await func()
zigpy.exceptions.DeliveryError: [0x26ac:0:0x0005]: Message send failure
2021-06-06 19:29:37 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:30:07 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:30:40 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:31:13 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:31:26 WARNING (MainThread) [zigpy.zdo] [0x86dc:zdo] Data remains after deserializing ZDO frame
2021-06-06 19:31:37 ERROR (MainThread) [custom_components.xiaomi_miot_raw.deps.xiaomi_cloud_new] Error while requesting MIoT api /user/get_user_device_data :
2021-06-06 19:31:37 ERROR (MainThread) [custom_components.xiaomi_miot_raw.deps.miot_coordinator] Unexpected error fetching xiaomi_miot_raw-319190-event-door data: 'NoneType' object is not subscriptable
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 187, in _async_refresh
self.data = await self._async_update_data()
File "/config/custom_components/xiaomi_miot_raw/deps/miot_coordinator.py", line 122, in _async_update_data
if result['code'] != 0:
TypeError: 'NoneType' object is not subscriptable
2021-06-06 19:31:47 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:32:19 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:32:51 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:33:23 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:33:55 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:34:28 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:35:01 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:35:26 WARNING (MainThread) [zigpy.zdo] [0x86dc:zdo] Data remains after deserializing ZDO frame
2021-06-06 19:35:35 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:36:06 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:36:40 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:37:09 WARNING (MainThread) [zigpy.zdo] [0x26ac:zdo] Data remains after deserializing ZDO frame
2021-06-06 19:37:11 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:37:19 WARNING (MainThread) [zigpy.device] [0x26ac] Requesting Node Descriptor failed
r = await func()
2021-06-06 19:37:35 WARNING (MainThread) [zigpy.device] [0x26ac] Failed to discover active endpoints
r = await func()
2021-06-06 19:37:45 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:38:14 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:38:45 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:39:16 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:39:26 WARNING (MainThread) [zigpy.zdo] [0x86dc:zdo] Data remains after deserializing ZDO frame
2021-06-06 19:39:49 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:40:21 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:40:54 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:41:09 WARNING (MainThread) [zigpy.zdo] [0x26ac:zdo] Data remains after deserializing ZDO frame
2021-06-06 19:41:19 WARNING (MainThread) [zigpy.device] [0x26ac] Requesting Node Descriptor failed
r = await func()
2021-06-06 19:41:27 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:41:35 WARNING (MainThread) [zigpy.device] [0x26ac] Failed to discover active endpoints
r = await func()
2021-06-06 19:41:45 ERROR (MainThread) [frontend.js.latest.202106030] :0:0 Script error.
2021-06-06 19:41:59 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:42:30 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:43:03 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:43:26 WARNING (MainThread) [zigpy.zdo] [0x86dc:zdo] Data remains after deserializing ZDO frame
2021-06-06 19:43:34 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:44:05 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:44:36 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:45:09 WARNING (MainThread) [zigpy.zdo] [0x26ac:zdo] Data remains after deserializing ZDO frame
2021-06-06 19:45:10 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:45:19 WARNING (MainThread) [zigpy.device] [0x26ac] Requesting Node Descriptor failed
r = await func()
2021-06-06 19:45:35 WARNING (MainThread) [zigpy.device] [0x26ac] Failed to discover active endpoints
r = await func()
2021-06-06 19:45:42 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:46:12 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:46:42 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:47:15 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:47:26 WARNING (MainThread) [zigpy.zdo] [0x86dc:zdo] Data remains after deserializing ZDO frame
2021-06-06 19:47:39 ERROR (MainThread) [homeassistant.components.hassio] The system cannot restart because the configuration is not valid: Platform error sensor.chineseholiday - Integration 'chineseholiday' not found.
2021-06-06 19:47:39 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [281472638538176] The system cannot restart because the configuration is not valid: Platform error sensor.chineseholiday - Integration 'chineseholiday' not found.
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1491, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1526, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 518, in async_handle_core_service
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Platform error sensor.chineseholiday - Integration 'chineseholiday' not found.
2021-06-06 19:47:46 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:48:18 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:48:51 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2021-06-06 19:49:09 WARNING (MainThread) [zigpy.zdo] [0x26ac:zdo] Data remains after deserializing ZDO frame
2021-06-06 19:49:19 WARNING (MainThread) [zigpy.device] [0x26ac] Requesting Node Descriptor failed
r = await func()
2021-06-06 19:49:22 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
发表于 2021-6-6 23:52:46 | 显示全部楼层
发表于 2021-6-7 11:32:28 | 显示全部楼层
我的也是这情况  不知道怎么解决?  昨天升级后HACS也不能用了,崩溃
发表于 2021-9-1 20:09:09 | 显示全部楼层
升级了,自定义插件就报错了
GMT+8, 2025-12-22 09:51 , Processed in 0.292990 second(s), 13 queries , MemCached On.
