楼主: weisong
[技术探讨] 海康单元门室内机接入hass
发表于 2021-6-3 23:25:09 | 显示全部楼层
weisong 发表于 2021-6-1 08:55
我现在通过萤石云API能post开锁,但是token7天一变,我就想在hass里面设置一个开关,然后开关打开运行一个p ...
Node-Red就可以
 楼主| 发表于 2021-6-5 14:37:15 | 显示全部楼层
怎么设置啊?能给个教程不?
发表于 2021-6-7 00:40:33 | 显示全部楼层
weisong 发表于 2021-6-5 14:37
怎么设置啊?能给个教程不?
权限太低上不了附件 只能给代码你自己导入。流程是每三天运行一次,把tocken取出来存到global里
需要在Http request里改一下你的key和secret
[{"id":"d26a8fa9.64fc7","type":"http request","z":"a2d4102a.2a9b3","name":"","method":"POST","ret":"txt","paytoqs":"ignore","url":"https://open.ys7.com/api/lapp/token/get?appKey=你自己的key&appSecret=你自己的Secret","tls":"","persist":false,"proxy":"","authType":"","x":280,"y":120,"wires":[["b0cc8f8.59d167"]]},{"id":"b0cc8f8.59d167","type":"json","z":"a2d4102a.2a9b3","name":"","property":"payload","action":"","pretty":false,"x":430,"y":120,"wires":[["f419f684.14e558"]]},{"id":"1cf6558c.04066a","type":"inject","z":"a2d4102a.2a9b3","name":"每三天更新","props":[{"p":"payload","v":"","vt":"date"},{"p":"topic","v":"","vt":"string"}],"repeat":"","crontab":"00 12 * * 3,0","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":110,"y":120,"wires":[["d26a8fa9.64fc7"]]},{"id":"f419f684.14e558","type":"change","z":"a2d4102a.2a9b3","name":"","rules":[{"t":"move","p":"payload.data.accessToken","pt":"msg","to":"token","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":120,"wires":[[]]}]
 楼主| 发表于 2021-7-26 20:15:30 | 显示全部楼层
太感谢了。。。。我去试试
发表于 2022-7-14 09:06:01 来自手机 | 显示全部楼层
楼主解决了吗  我也想控制单元门禁
Ari 手机认证
发表于 2022-7-14 15:07:06 | 显示全部楼层
同海康,插网线的。尴尬,估计是没戏
GMT+8, 2026-1-18 19:46 , Processed in 0.353026 second(s), 11 queries , MemCached On.
