查看: 5163|回复: 0
[求助] 安卓手机安装hass, 在python 虚拟环境中使用 pip 命令出现错误
发表于 2021-5-31 10:17:07 | 显示全部楼层 |阅读模式
设置过 root 的密码!
也用visudo 开放了用户权限
进入虚拟环境 使用 pip 或者 pip3 都会出现 这串错误! 但是推出虚拟环境就都没问题了?
  Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f76ad8400>: Failed to establish a new connection: [Errno -2] 未知的名称或服务')': /pypi/simple/homeassistant/
  Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f76ad8320>: Failed to establish a new connection: [Errno -2] 未知的名称或服务')': /pypi/simple/homeassistant/
  Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f76c9ca20>: Failed to establish a new connection: [Errno -2] 未知的名称或服务')': /pypi/simple/homeassistant/
  Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f76c9c438>: Failed to establish a new connection: [Errno -2] 未知的名称或服务')': /pypi/simple/homeassistant/
  Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f76c9c5f8>: Failed to establish a new connection: [Errno -2] 未知的名称或服务')': /pypi/simple/homeassistant/
  Could not find a version that satisfies the requirement homeassistant (from versions: )
No matching distribution found for homeassistant
请求大神解惑!!!
GMT+8, 2025-12-22 15:12 , Processed in 1.138725 second(s), 7 queries , MemCached On.
