查看: 2141|回复: 3
[技术探讨] 求助!云音乐用mpd播放怎么搞都没声音
发表于 2021-5-27 11:25:13 来自手机 | 显示全部楼层 |阅读模式
我是群晖安装的hassOS,云音乐用mpd播放怎么搞都没声音下面是mpd日志,哪位大佬帮我看看是怎么回事啊INFO     Scanned 0 of 0 files in 0s.
INFO     Done scanning.
INFO     Starting Mopidy 2.2.2
INFO     Loading config from builtin defaults
INFO     Loading config from /var/lib/mopidy/.config/mopidy/mopidy.conf
INFO     Loading config from command line options
INFO     Enabled extensions: iris, mpd, http, file, stream, m3u, softwaremixer, moped, local-images, local, local-sqlite
INFO     Disabled extensions: spotify, gmusic
WARNING  Found gmusic configuration errors, the extension has been automatically disabled:
WARNING    gmusic/username must be set.
WARNING    gmusic/password must be set.
WARNING  Found spotify configuration errors, the extension has been automatically disabled:
WARNING    spotify/username must be set.
WARNING    spotify/client_secret must be set.
WARNING    spotify/password must be set.
WARNING    spotify/client_id must be set.
WARNING  Please fix the extension configuration errors or disable the extensions to silence these messages.
INFO     Starting Mopidy mixer: SoftwareMixer
INFO     Starting Mopidy audio
INFO     Starting Mopidy backends: StreamBackend, M3UBackend, FileBackend, LocalBackend
INFO     Loaded 0 local tracks using sqlite
INFO     Starting Mopidy core
INFO     Audio output set to "autoaudiosink"
ERROR    M3UBackend backend caused an exception.
  File "/usr/lib/python2.7/dist-packages/mopidy/core/playlists.py", line 18, in _backend_error_handling
    yield
  File "/usr/lib/python2.7/dist-packages/mopidy/core/playlists.py", line 66, in as_list
    playlists = future.get()
  File "/usr/lib/python2.7/dist-packages/pykka/threading.py", line 52, in get
    compat.reraise(*self._data['exc_info'])
  File "/usr/lib/python2.7/dist-packages/pykka/compat.py", line 12, in reraise
    exec('raise tp, value, tb')
  File "/usr/lib/python2.7/dist-packages/pykka/actor.py", line 201, in _actor_loop
    response = self._handle_receive(message)
  File "/usr/lib/python2.7/dist-packages/pykka/actor.py", line 295, in _handle_receive
    return callee(*message['args'], **message['kwargs'])
  File "/usr/lib/python2.7/dist-packages/mopidy/m3u/playlists.py", line 70, in as_list
    for entry in os.listdir(self._playlists_dir):
OSError: [Errno 2] No such file or directory: '/share/mopidy/playlists'
INFO     Starting Mopidy frontends: IrisFrontend, MpdFrontend, HttpFrontend
INFO     Starting Iris 3.33.0
INFO     MPD server running at [::ffff:0.0.0.0]:6600
INFO     Starting GLib mainloop
INFO     HTTP server running at [::ffff:0.0.0.0]:6680
INFO     New MPD connection from [::ffff:172.30.33.3]:6600
    yield
    yield
    yield
WARNING  Could not find a MPEG-1 Layer 3 (MP3) decoder to handle media.
WARNING  GStreamer warning: gst-stream-error-quark: No decoder available for type 'audio/mpeg, mpegversion=(int)1, mpegaudioversion=(int)1, layer=(int)3, rate=(int)48000, channels=(int)2, parsed=(boolean)true'. (6)
ERROR    GStreamer error: gst-core-error-quark: Your GStreamer installation is missing a plug-in. (12)
 楼主| 发表于 2021-5-27 11:26:22 来自手机 | 显示全部楼层
我是群晖虚拟机安装的hassOS
发表于 2021-5-27 22:31:55 | 显示全部楼层
在MPD設定聲音輸有沒有聲卡選擇呢..
 楼主| 发表于 2021-5-28 09:01:37 | 显示全部楼层
bossben8 发表于 2021-5-27 22:31
在MPD設定聲音輸有沒有聲卡選擇呢..
音频输入和输出都是默认,选择不了。还要装什么插件吗?
GMT+8, 2025-12-28 22:19 , Processed in 1.420521 second(s), 11 queries , MemCached On.
