查看: 18398|回复: 5
[求助] ESPHome 长按和短按该怎么写?
发表于 2021-5-23 14:44:16 | 显示全部楼层 |阅读模式
  - platform: gpio
    pin:
      number: D5
      inverted: True
      mode: INPUT_PULLUP
    on_click:
        - light.dim_relative:
             relative_brightness: 15%
             transition_length: 0.1s
现在是这样写的,D5被按一下亮度增加15%
想增加长按功能,长按2秒以上持续增加亮度,或者通过长按2秒以上重复触发light.dim_relative也可以。求大神帮忙
发表于 2021-5-23 15:40:51 | 显示全部楼层
不懂帮顶
发表于 2021-5-23 15:58:32 | 显示全部楼层
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    internal: true
    on_multi_click:
    - timing:
        - ON for at most 0.8s
        - OFF for at most 0.5s
        - OFF for at least 0.2s
      then:
        - logger.log: "Double Clicked"
        - homeassistant.service:
            service: cover.toggle
            data:
              entity_id: cover.curtain
    - timing:
        - ON for at least 0.8s
      then:
        - logger.log: "Single Long Clicked"
        - if:
            condition:
              binary_sensor.is_on: binary_sensor_moonlight
            then:
              - logger.log: "normal"
                  service: yeelight.set_mode
                  data:
                    entity_id: light.yeelight_ceiling
                    mode: normal
            else:
              - logger.log: "moonlight"
                  data:
                    mode: moonlight
 楼主| 发表于 2021-5-24 02:22:44 | 显示全部楼层
谢谢,但需要回调homeassistant在断网的时候没有保证了,还是希望最好能在esp内部运行
智能家居&单板滑雪痴迷爱好者
发表于 2021-5-24 08:11:21 | 显示全部楼层
on_click本身就可以设置时长:
binary_sensor:
  - platform: gpio
    on_click:
      min_length: 50ms
      max_length: 350ms
      then:
        - switch.turn_off: relay_1
你把min_length设置大一点应该就可以实现长按的效果
发表于 2021-5-25 20:27:43 | 显示全部楼层
dizherui 发表于 2021-5-24 02:22
谢谢,但需要回调homeassistant在断网的时候没有保证了,还是希望最好能在esp内部运行 ...
我的是yeelight的吸顶,一直通电的,断网也只能蓝牙控,只用then之前的就可以了,之后的执行动作按需修改。
GMT+8, 2025-12-16 02:08 , Processed in 0.385675 second(s), 4 queries , MemCached On.
