查看: 18704|回复: 3
[求助] 升级ha2021.4版本后broadlink_cover插件报错
发表于 2021-5-7 16:06:24 | 显示全部楼层 |阅读模式
Error while setting up broadlink_cover platform for cover
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 231, in _async_setup_platform
    await asyncio.shield(task)
  File "/usr/local/lib/python3.8/asyncio/coroutines.py", line 124, in coro
    res = func(*args, **kw)
  File "/config/custom_components/broadlink_cover/cover.py", line 105, in async_setup_platform
    broadlink_device.auth()
  File "/usr/local/lib/python3.8/site-packages/broadlink/device.py", line 186, in auth
    response = self.send_packet(0x65, payload)
  File "/usr/local/lib/python3.8/site-packages/broadlink/device.py", line 267, in send_packet
    packet[0x24:0x26] = self.devtype.to_bytes(2, "little")
AttributeError: 'NoneType' object has no attribute 'to_bytes'
发表于 2021-10-24 20:04:42 | 显示全部楼层
那个插件好像也没更新了,楼主解决了吗
 楼主| 发表于 2021-10-26 14:53:42 | 显示全部楼层
yotashop 发表于 2021-10-24 20:04
那个插件好像也没更新了,楼主解决了吗
弃用了,,直接用cover模板
发表于 2021-10-26 18:50:46 | 显示全部楼层
shavn1984 发表于 2021-10-26 14:53
弃用了,,直接用cover模板
https://github.com/nagyrobi/home ... cover-rf-time-based  我用这个搞定了
GMT+8, 2025-12-22 05:50 , Processed in 0.265640 second(s), 4 queries , MemCached On.
