查看: 19624|回复: 1
[技术探讨] 开关,求指点!
发表于 2021-5-6 21:05:59 | 显示全部楼层 |阅读模式
这是我的开关。 上面那个的定义如下,上面图片 是2组开关。我现在想实现的是如果当前状态是开启状态。那么下面的开启开关就不能使用。如果是关闭状态 关闭开关就不能使用。
求各位大神指点。
还有种需求是2个开关互锁,打开一个就不能打开另外一个。。谢谢
binary_sensor:
  - platform: mqtt
    state_topic: "sensor/zj/302/IntData"
    value_template: "{{ value[3] }}"
    payload_on: "0"
    payload_off: "1"
    device_class: opening
下面的开关定义是
switch:
  - platform: mqtt
    icon: mdi:air-filter
    state_topic: "sensor/zj/302/OutData"
    command_topic: "sensor/zj/set/302/01"
    value_template: "{{ value[1] }}"
    payload_on: "4:1"
    payload_off: "4:0"
    state_on: "1"
    state_off: "0"
    optimistic: false
    qos: 0
    retain: false
  - platform: mqtt
    icon: mdi:lightbulb-outline
    command_topic: "sensor/zj/set/302/02"
    value_template: "{{ value[0] }}"
    payload_on: "17:1"
    payload_off: "17:0"
    state_on: "1"
    state_off: "0"
    optimistic: false
    qos: 0
    retain: false
 楼主| 发表于 2021-5-7 14:40:05 | 显示全部楼层
顶一下。求解答
GMT+8, 2025-12-29 00:16 , Processed in 0.727303 second(s), 12 queries , MemCached On.
