楼主: Retroposter
[插件集成] [weibo] 监控指定用户微博
发表于 2020-2-18 16:16:55 | 显示全部楼层
学习一下
发表于 2020-2-26 19:50:01 | 显示全部楼层
这也行赶紧来看看
发表于 2020-3-6 10:13:14 | 显示全部楼层
非常棒非常棒
发表于 2020-3-6 10:17:37 | 显示全部楼层
非常棒非常棒非常棒非常棒非常棒
发表于 2020-3-20 17:58:59 来自手机 | 显示全部楼层
太好了不知道现在还能用不
发表于 2020-3-20 20:08:26 | 显示全部楼层
大神更新下版本把  现在不能用了
Error while setting up platform weibo
  File "/config/custom_components/weibo/sensor.py", line 132, in _update
    for tab in rep.json()['tabsInfo']['tabs']:
KeyError: 'tabsInfo'
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
    await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/config/custom_components/weibo/sensor.py", line 58, in setup_platform
    weibo_data.update()
  File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 240, in wrapper
    result = method(*args, **kwargs)
  File "/config/custom_components/weibo/sensor.py", line 136, in _update
    _LOGGER.error('Failed to get containerid', ex)
  File "/usr/local/lib/python3.7/logging/__init__.py", line 1407, in error
    self._log(ERROR, msg, args, **kwargs)
  File "/usr/local/lib/python3.7/logging/__init__.py", line 1514, in _log
    self.handle(record)
  File "/usr/local/lib/python3.7/logging/__init__.py", line 1524, in handle
    self.callHandlers(record)
  File "/usr/local/lib/python3.7/logging/__init__.py", line 1586, in callHandlers
    hdlr.handle(record)
  File "/usr/local/lib/python3.7/logging/__init__.py", line 894, in handle
    self.emit(record)
  File "/usr/src/homeassistant/homeassistant/components/system_log/__init__.py", line 176, in emit
    record, stack, _figure_out_source(record, stack, self.hass)
  File "/usr/src/homeassistant/homeassistant/components/system_log/__init__.py", line 102, in __init__
    self.message = record.getMessage()
  File "/usr/local/lib/python3.7/logging/__init__.py", line 369, in getMessage
    msg = msg % self.args
TypeError: not all arguments converted during string formatting
连接中断。正在重新连接...
发表于 2020-4-1 14:58:29 | 显示全部楼层
看看是不是我需要的
发表于 2020-4-6 12:44:29 | 显示全部楼层
谢谢分享
jove 手机认证
发表于 2020-4-7 23:31:56 | 显示全部楼层
感谢分享~
发表于 2020-5-3 00:03:56 | 显示全部楼层
微博虽然只是看新闻,但是有这个功能也是美滋滋啊
GMT+8, 2026-1-17 13:30 , Processed in 0.441192 second(s), 11 queries , MemCached On.
