查看: 27131|回复: 6
[求助] zigbee2mqtt插件起不来
发表于 2021-4-30 01:56:45 | 显示全部楼层 |阅读模式
之前一直用zha,最近买了个开关zha不支持,所以想试试zigbee2mqtt。把米家多模网关调到了zigbee2mqtt模式,然后按照alex大神的视频安装了zigbee2mqtt edge,修改配置:
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://192.168.50.8:1883'
  user: mqtt
  password: mqtt
serial:
  port: 'tcp://192.168.50.38:8888'
  adapter: ezsp
advanced:
  log_level: info
  pan_id: 6754
  channel: 11
  network_key:
    - 1
    - 3
    - 5
    - 7
    - 9
    - 11
    - 13
    - 15
    - 0
    - 2
    - 4
    - 6
    - 8
    - 10
    - 12
    - 13
  availability_blocklist: []
  availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
  port: 8099
experimental: {}
socat:
  enabled: false
  master: 'pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777'
  slave: 'tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5'
  options: '-d -d'
  log: false
启动后一直是这样:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[17:50:30] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[17:50:31] INFO: MQTT available, fetching server detail ...
[17:50:31] INFO: Previous config file found, checking backup
[17:50:31] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[17:50:31] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[17:50:32] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start /app
> node index.js
Zigbee2MQTT:info  2021-04-29 17:50:37: Logging to console and directory: '/config/zigbee2mqtt/log/2021-04-29.17-50-35' filename: log.txt
Zigbee2MQTT:info  2021-04-29 17:50:37: Starting Zigbee2MQTT version 1.18.2-dev (commit #d61d6e2)
Zigbee2MQTT:info  2021-04-29 17:50:37: Starting zigbee-herdsman (0.13.92)
应该是这个 zigbee-herdsman起不来,有大佬遇到过么?
发表于 2021-4-30 08:59:35 | 显示全部楼层
 楼主| 发表于 2021-4-30 12:45:39 | 显示全部楼层
peter5858 发表于 2021-4-30 08:59
换地址  https://github.com/zigbee2mqtt/hassio-zigbee2mqtt
重新安装
重新安装,重启几次后莫名好了,不确定哪一步的问题,感谢!
发表于 2021-6-1 21:10:39 | 显示全部楼层
我也是这个问题,你的解决了没
 楼主| 发表于 2021-6-2 12:13:30 | 显示全部楼层
wang3356 发表于 2021-6-1 21:10
我也是这个问题,你的解决了没
重启了几次网关后起来了
但是在我这运行的不稳定,24~48小时后会不响应,目前已切回zha模式
发表于 2021-6-6 21:08:04 | 显示全部楼层
froggyfly 发表于 2021-6-2 12:13
重启了几次网关后起来了
但是在我这运行的不稳定,24~48小时后会不响应,目前已切回zha模式 ...
请问ZHA如何接入不支持的设备呢?
发表于 2021-6-19 21:43:58 | 显示全部楼层
重启了几次网关后起来了
是的 后面突然就可以啦,现在还挺稳定的
GMT+8, 2025-12-22 15:00 , Processed in 1.880185 second(s), 9 queries , MemCached On.
