查看: 10604|回复: 20
[技术探讨] 求助:hello_miai 提示“还未登录”【已解决】
发表于 2021-4-26 13:49:56 | 显示全部楼层 |阅读模式
hello_miai插件,通过小爱TTS,前几天都是正常,昨天开始出现没有声音,服务里面有hello_miai对应的几个服务,但只要涉及语音播报日志提示:还未登录。
日志如下:
Logger: custom_components.hello_miai
Source: custom_components/hello_miai/__init__.py:388
Integration: hello_miai (documentation)
First occurred: 下午12:27:00 (1 occurrences)
Last logged: 下午12:27:00
还未登录
111
111
方法是论坛上找到的,有大神重新写了插件里面的py文件,链接如下:
https://bbs.hassbian.com/thread-3669-124-5.html
复制一下代码,替换插件里面py文件的内容,重启即可。
import json
import urllib
import requests
import os, re, random, string
import hashlib
import time
import base64
import hass_frontend
from urllib import parse
from threading import Thread, Event
import logging
_LOGGER = logging.getLogger(__name__)
class xiaomi_tts:
    def __init__(self, hass, config, user=None, password=None):
        requests.packages.urllib3.disable_warnings()
        self.login_resutl = False
        self.config = config
        self.hass = hass
        self._CONFIGURING = {}
        self._user = user
        self._password = password
        self.Service_Token = None
        self.deviceIds = None
        self.userId = None
        self._cookies = {}
        self._request = requests.session()
        self._headers = {'Host': 'account.xiaomi.com',
                         'Connection': 'keep-alive',
                         'Upgrade-Insecure-Requests': '1',
                         'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/65.0.3325.181 Safari/537.36',
                         'Accept': 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8',
                         'Accept-Encoding': 'gzip, deflate, br',
                         'Accept-Language': 'zh-CN,zh;q=0.9'}
        self._LoginByPassord()
        # else:
        #     self._LoginByPassord()#No write permission
    @property
    def Service_Token_Cookie(self):
        return self.Service_Token
    @property
    def Login_resutl(self):
        return self.login_resutl
    @property
    def deviceIds_miai(self):
        return self.deviceIds
    def request_app_setup(self, image_name):
        """Assist user with configuring the Fitbit dev application."""
        configurator = self.hass.components.configurator
        try:
            self.hass.components.configurator.request_done(self._CONFIGURING.pop("MIAI"))
        except:
            pass
        def fitbit_configuration_callback(callback_data):
            self._serviceLoginAuth2(callback_data.get('code'))
            if self._serviceLoginAuth2_json['code'] == 0:
                if not self._login_miai():
                    _LOGGER.warning('login miai Failed')
                else:
                    if not self._get_deviceId():
                        _LOGGER.warning('get_deviceId Failed')
            elif self._serviceLoginAuth2_json['code'] == 70016:
                _LOGGER.warning('incorrect password')
            elif self._serviceLoginAuth2_json['code'] == 87001:
                _LOGGER.warning('incorrect codes')
            else:
                _LOGGER.error(self._serviceLoginAuth2_json)
            if self.Service_Token != None and self.deviceIds != None:
                self.login_resutl = True
        description = """请输入验证码"""
        submit = "登录"
        self._CONFIGURING['MIAI'] = configurator.request_config(
            'MIAI', fitbit_configuration_callback,
            description=description, submit_caption=submit,
            description_image="/static/images/miai{}.jpg".format(image_name),
            fields=[{'id': 'code', 'name': '验证码', 'type': ''}]
    def _LoginByPassord(self):
        if not self._get_sign():
            _LOGGER.warning("get_sign Failed")
        else:
            if not self._serviceLoginAuth2():
                _LOGGER.warning('Request Login_url Failed')
            else:
                    # logon success,run self._login_miai()
                    else:
                    self._headers['Cookie'] = self._headers['Cookie'] + '; pwdToken={}'.format(
                        self._cookies['pwdToken'])
                    path = os.path.dirname(hass_frontend.__file__)
                    try:
                        current_time = int(round(time.time() * 1000))
                        r = self._request.get(
                            'https://account.xiaomi.com/pass/getCode?icodeType=login&{}'.format(current_time),
                            headers=self._headers, timeout=3, cookies=self._cookies, verify=False)
                        self._cookies['ick'] = self._request.cookies.get_dict()['ick']
                        if os.access(path + '/images', os.W_OK):
                            with open(path + '/images' + '/miai{}.jpg'.format(current_time), 'wb') as f:
                                f.write(r.content)
                                f.close()
                            self.request_app_setup(current_time)
                    except IOError as e:
                        _LOGGER.warning(e)
                    except BaseException as e:
                        _LOGGER.warning(e)
                    _LOGGER.error('incorrect password')
    def _get_sign(self):
        url = 'https://account.xiaomi.com/pass/serviceLogin'
        pattern = re.compile(r'_sign=(.*?)&')
        try:
            r = self._request.get(url, headers=self._headers, timeout=3, verify=False)
            self._cookies['pass_trace'] = self._request.cookies.get_dict().get('pass_trace')
            self._sign = pattern.findall(r.url)[0]
            return True
            _LOGGER.warning(e)
            return False
    def _serviceLoginAuth2(self, captCode=None):
        url = 'https://account.xiaomi.com/pass/serviceLoginAuth2'
        self._headers['Content-Type'] = 'application/x-www-form-urlencoded'
        self._headers['Accept'] = '*/*'
        self._headers['Origin'] = 'https://account.xiaomi.com'
        self._headers['Referer'] = 'https://account.xiaomi.com/pass/serviceLogin?sid=micoapi'
        # self._headers['Cookie']='pass_ua={}; deviceId={}; pass_trace={}; uLocale={}; JSESSIONID={}'.format(self._cookies['pass_ua'],self._cookies['deviceId'],self._cookies['pass_trace'],self._cookies['uLocale'],self._cookies['JSESSIONID'])
        self._headers['Cookie'] = 'pass_trace={};'.format(self._cookies['pass_trace'])
        auth_post_data = {'_json': 'true',
                          '_sign': self._sign,
                          'callback': 'https://api.mina.mi.com/sts',
                          'hash': hashlib.md5(self._password.encode('utf-8')).hexdigest().upper(),
                          'qs': '%3Fsid%3Dmicoapi',
                          'serviceParam': '{"checkSafePhone":false}',
                          'sid': 'micoapi',
                          'user': self._user}
        try:
            if captCode != None:
                url = 'https://account.xiaomi.com/pass/serviceLoginAuth2?_dc={}'.format(int(round(time.time() * 1000)))
                auth_post_data['captCode'] = captCode
                self._headers['Cookie'] = self._headers['Cookie'] + '; ick={}'.format(self._cookies['ick'])
            r = self._request.post(url, headers=self._headers, data=auth_post_data, timeout=3, cookies=self._cookies,
                                   verify=False)
            self._cookies['pwdToken'] = self._request.cookies.get_dict()['passToken']
            self._serviceLoginAuth2_json = json.loads(r.text[11:])
            return True
            return False
            _LOGGER.warning(e)
    def _login_miai(self):
        serviceToken = "nonce={}&{}".format(self._serviceLoginAuth2_json['nonce'],
                                            self._serviceLoginAuth2_json['ssecurity'])
        serviceToken_sha1 = hashlib.sha1(serviceToken.encode('utf-8')).digest()
        base64_serviceToken = base64.b64encode(serviceToken_sha1)
        loginmiai_header = {'User-Agent': 'MISoundBox/1.4.0,iosPassportSDK/iOS-3.2.7 iOS/11.2.5',
                            'Accept-Language': 'zh-cn', 'Connection': 'keep-alive'}
        url = self._serviceLoginAuth2_json['location'] + "&clientSign=" + parse.quote(base64_serviceToken.decode())
        try:
            r = self._request.get(url, headers=loginmiai_header, timeout=3, verify=False)
            if r.status_code == 200:
                self._Service_Token = self._request.cookies.get_dict()['serviceToken']
                self.userId = self._request.cookies.get_dict()['userId']
                return True
            else:
                return False
            _LOGGER.warning(e)
            return False
    def _get_deviceId(self):
        url = 'https://api.mina.mi.com/admin/v2/device_list?master=1&requestId=CdPhDBJMUwAhgxiUvOsKt0kwXThAvY'
        get_deviceId_header = {'Cookie': 'userId={};serviceToken={}'.format(self.userId, self._Service_Token)}
        try:
            r = self._request.get(url, headers=get_deviceId_header, timeout=3, verify=False)
            model = {"Cookie": "userId={};serviceToken={}".format(self.userId, self._Service_Token),
                     "deviceId": json.loads(r.text)['data']}
            self.Service_Token = model['Cookie']
            self.deviceIds = model['deviceId']
            return True
            _LOGGER.warning(e)
            return False
    def _text_to_speech(self, text, tts_cookie, deviceIds_miai, num=0):
        try:
            url = "https://api.mina.mi.com/remote/ubus?deviceId={}&message=%7B%22text%22%3A%22{}%22%7D&method=text_to_speech&path=mibrain&requestId={}".format(
                self.deviceIds_miai[num]['deviceID'], parse.quote(text),
                ''.join(random.sample(string.ascii_letters + string.digits, 30)))
            r = self._request.post(url, headers={'Cookie': tts_cookie}, timeout=10, verify=False)
            if json.loads(r.text)['message'] == 'Success':
                return True
            elif json.loads(r.text)['error'] == 'ubus error':
                _LOGGER.error(json.loads(r.text))
            elif json.loads(r.text)['error'] == 'Unauthorized':
                return False
            else:
                # self.login_resutl = False
                return True
        except IndexError as e:
            _LOGGER.error('你没有那个音箱!')
        except AttributeError as e:
            _LOGGER.warning(e)
            _LOGGER.warning(e)
        return True
    def player_set_volume(self, volume, tts_cookie, deviceIds_miai, num=0):
        if volume > 100:
            volume = 100
        elif volume < 0:
            volume = 0
        try:
            url = "https://api.mina.mi.com/remote/ubus?deviceId={}&message=%7b%22volume%22%3a{}%2c%22media%22%3a%22app_ios%22%7d&method=player_set_volume&path=mediaplayer&requestId={}".format(
                self.deviceIds_miai[num]['deviceID'], int(volume),
                return True
                return False
            else:
                return False
            return True
            _LOGGER.warning(e)
            _LOGGER.warning(e)
        return True
    def player_play_operation(self, operation, tts_cookie, deviceIds_miai, num=0):
        try:
            url = "https://api.mina.mi.com/remote/ubus?deviceId={}&message=%7b%22action%22%3a%22{}%22%2c%22media%22%3a%22app_ios%22%7d&method=player_play_operation&path=mediaplayer&requestId={}".format(
                self.deviceIds_miai[num]['deviceID'], operation,
                return True
                return False
            else:
                return False
            _LOGGER.warning(e)
            _LOGGER.warning(e)
        return True
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
CONF_USER = 'miid'
CONF_PASSWORD = 'password'
CONF_TO_NUM = 'miai_num'
WAIT_TIME = 'wait_time'
ATTR_MESSAGE = 'message'
ATTR_VOLUME = 'vol'
DEFAULT_MIAI_NUM = '0'
DEFAULT_MIAI_SPEED = 0.27
DEFAULT_WAIT_TIME = 0
DOMAIN = 'hello_miai'
SERVICE_SCHEMA = vol.Schema({
    vol.Required(ATTR_MESSAGE): cv.string,
    vol.Optional(CONF_TO_NUM): cv.string,
SERVICE_SCHEMA_FOR_QUEUE = vol.Schema({
    vol.Optional(WAIT_TIME): cv.string,
SERVICE_SCHEMA_FOR_SET_VOLUME = vol.Schema({
    vol.Required(ATTR_VOLUME): cv.string,
SERVICE_SCHEMA_FOR_PLAY_OPERATION = vol.Schema({
CONFIG_SCHEMA = vol.Schema({
    DOMAIN: vol.Schema({
        vol.Required(CONF_USER): cv.string,
        vol.Required(CONF_PASSWORD): cv.string,
}, extra=vol.ALLOW_EXTRA)
def setup(hass, config):
    conf = config.get(DOMAIN, {})
    miid = conf.get(CONF_USER)
    password = conf.get(CONF_PASSWORD)
    client = xiaomi_tts(hass, config, miid, password)
    msg_queue = []
    def listen_to_msg():
        while not Event().isSet():
            if client.Login_resutl:
                if len(msg_queue) > 0:
                    send_finish = client._text_to_speech(msg_queue[0]['msg'], client.Service_Token_Cookie,
                                                         client.deviceIds_miai, int(msg_queue[0]['to_num']))
                    if send_finish == True:
                        try:
                            time.sleep(len(msg_queue[0]['msg']) * DEFAULT_MIAI_SPEED + int(msg_queue[0]['wait_time']))
                        except:
                            time.sleep(len(msg_queue[0]['msg']) * DEFAULT_MIAI_SPEED)
                        msg_queue.pop(0)
                    else:
                        client._LoginByPassord()
                        time.sleep(1)
                else:
                    time.sleep(1)
            else:
                time.sleep(10)
    def send_message(call):
        msg_queue = []
        to_num = call.data.get(CONF_TO_NUM, DEFAULT_MIAI_NUM)
        message = call.data.get(ATTR_MESSAGE)
        if client.Service_Token_Cookie == None or client.deviceIds_miai == None:
            _LOGGER.error("还未登录")
        else:
            if not client._text_to_speech(message, client.Service_Token_Cookie, client.deviceIds_miai, int(to_num)):
    def add_msg2queue(call):
        wait_time = call.data.get(WAIT_TIME, DEFAULT_WAIT_TIME)
        else:
            msg_queue.append({'msg': message, 'to_num': to_num, 'wait_time': wait_time})
    def player_set_volume(call):
        vol = call.data.get(ATTR_VOLUME)
        else:
            if not client.player_set_volume(int(vol), client.Service_Token_Cookie, client.deviceIds_miai, int(to_num)):
    def play_operation(call):
        else:
            if not client.player_play_operation('play', client.Service_Token_Cookie, client.deviceIds_miai,
                                                int(to_num)):
                client.player_play_operation('play', client.Service_Token_Cookie, client.deviceIds_miai, int(to_num))
    def pause_operation(call):
        else:
            if not client.player_play_operation('pause', client.Service_Token_Cookie, client.deviceIds_miai,
                                                int(to_num)):
                client.player_play_operation('pause', client.Service_Token_Cookie, client.deviceIds_miai, int(to_num))
    def listen():
        """Start listening."""
        thread = Thread(target=listen_to_msg, args=())
        thread.daemon = True
        thread.start()
    listen()
    def _stop_listener(_event):
        Event.set()
    hass.bus.listen_once(
        "homeassistant_stop",
        _stop_listener
    hass.services.register(DOMAIN, 'force_send', send_message,
                           schema=SERVICE_SCHEMA)
    hass.services.register(DOMAIN, 'add2MsgQueue', add_msg2queue,
                           schema=SERVICE_SCHEMA_FOR_QUEUE)
    hass.services.register(DOMAIN, 'set_vol', player_set_volume,
                           schema=SERVICE_SCHEMA_FOR_SET_VOLUME)
    hass.services.register(DOMAIN, 'play', play_operation,
                           schema=SERVICE_SCHEMA_FOR_PLAY_OPERATION)
    hass.services.register(DOMAIN, 'pause', pause_operation,
    return True
发表于 2021-4-26 13:56:26 | 显示全部楼层
账号密码配置了吗?
我不生产技术,我只是技术的搬运工。
发表于 2021-4-26 14:01:38 | 显示全部楼层
我的今天也出现这个问题了
 楼主| 发表于 2021-4-26 14:17:39 | 显示全部楼层
zxyny1989 发表于 2021-4-26 13:56
账号密码配置了吗?
配置了的,前几天都是正常的,就这两天出问题了。
发表于 2021-4-26 14:26:49 | 显示全部楼层
那就不知道了,我很久不用这个了。
我不生产技术,我只是技术的搬运工。
发表于 2021-4-26 18:43:29 | 显示全部楼层
我说一下我曾经遇到这种情况的情形给楼主做个参考。我是出国访问配置了全局模式后,所有需要登录米家账号的插件都会出现这个类似的问题,猜测可能中国区米家账号用外国IP登录会有限制吧。
 楼主| 发表于 2021-4-26 20:59:33 | 显示全部楼层
firelion 发表于 2021-4-26 18:43
我说一下我曾经遇到这种情况的情形给楼主做个参考。我是出国访问配置了全局模式后,所有需要登录米家账号的 ...
爬墙已经退出全局模式,重启主机后还是的呢,应该怎么操作呢
 楼主| 发表于 2021-4-26 21:03:22 | 显示全部楼层
昨天就出现了,今天一天都是这种状态
发表于 2021-4-27 00:41:56 | 显示全部楼层
+1我也出现这个问题了
发表于 2021-4-27 03:31:31 | 显示全部楼层
选择绕过中国ip模式
GMT+8, 2025-12-2 15:55 , Processed in 0.396298 second(s), 10 queries , MemCached On.
