查看: 17539|回复: 6
[求助] hassio中Node-RED出现502 bad gateway怎么解决
发表于 2021-4-16 14:53:04 | 显示全部楼层 |阅读模式
请问hassio中Node-RED出现502 bad gateway怎么解决,按照https://blog.csdn.net/weixin_44968310/article/details/102757153仍然无法解决,网上也找不到其他办法,请问各位有出现吗?
发表于 2021-4-16 17:13:03 | 显示全部楼层
credential_secret: 輸入任意大+小寫英數
dark_mode: false
http_node:
  username: 輸入任意大+小寫英數
  password: 輸入任意大+小寫英數
http_static:
兩處的帳號與密碼不要重複,自己是這樣解決的
发表于 2021-4-16 21:43:53 | 显示全部楼层
Log里面应该有详细的错误信息
发表于 2023-5-26 10:35:29 | 显示全部楼层
解决了么我的出现了和你一样的情况
发表于 2023-5-31 16:46:19 | 显示全部楼层
试了好多次了,不行啊。
哪位大神帮解决一下
发表于 2023-6-8 07:16:56 | 显示全部楼层
我也是这个问题,有大神帮忙看看吗?
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 14.2.2
You are running the latest version of this add-on.
System: Home Assistant OS 10.2  (amd64 / qemux86-64)
Home Assistant Core: 2023.5.4
Home Assistant Supervisor: 2023.06.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
/etc/s6-overlay/s6-rc.d/init-nodered/run: line 68:   215 Illegal instruction     (core dumped) npm uninstall node-red-contrib-home-assistant node-red-contrib-home-assistant-llat node-red-contrib-home-assistant-ws
[07:16:29] WARNING: Failed un-installing conflicting packages
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service init-nginx successfully started
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
[07:16:29] INFO: Starting Node-RED...
[07:16:29] INFO: Service Node-RED exited with code 256 (by signal 4)
[07:16:31] INFO: Starting Node-RED...
[07:16:31] INFO: Service Node-RED exited with code 256 (by signal 4)
[07:16:32] INFO: Starting Node-RED...
[07:16:32] INFO: Service Node-RED exited with code 256 (by signal 4)
[07:16:33] INFO: Starting Node-RED...
[07:16:33] INFO: Service Node-RED exited with code 256 (by signal 4)
[07:16:34] INFO: Starting Node-RED...
[07:16:35] INFO: Service Node-RED exited with code 256 (by signal 4)
[07:16:36] INFO: Starting Node-RED...
[07:16:36] INFO: Service Node-RED exited with code 256 (by signal 4)
发表于 2023-6-8 09:24:12 | 显示全部楼层
我也遇到过这个问题,最后我nodered没有通过HA的加载项安装,找了个虚拟机单独安装的nodered
GMT+8, 2025-12-17 14:05 , Processed in 0.835720 second(s), 13 queries , MemCached On.
