查看: 5672|回复: 1
[求助] 威联通NAS 安装MQTT出现以下错误,怎么办
发表于 2021-4-13 18:03:06 | 显示全部楼层 |阅读模式
1618307684: For more details see https://mosquitto.org/documentation/authentication-methods/
1618307684: Opening ipv4 listen socket on port 1883.
1618307684: Opening ipv6 listen socket on port 1883.
1618307684: Error: Address not available
1618307684: mosquitto version 2.0.10 running
1618307949: mosquitto version 2.0.10 terminating
1618307953: mosquitto version 2.0.10 starting
1618307953: Config loaded from /mosquitto/config/mosquitto.conf.
1618307953: Starting in local only mode. Connections will only be possible from clients running on this machine.
1618307953: Create a configuration file which defines a listener to allow remote access.
1618307953: For more details see https://mosquitto.org/documentation/authentication-methods/
1618307953: Opening ipv4 listen socket on port 1883.
1618307953: Opening ipv6 listen socket on port 1883.
1618307953: Error: Address not available
1618307953: mosquitto version 2.0.10 running
发表于 2021-4-14 08:00:43 | 显示全部楼层
使用网桥模式,并且手动指定IP试试
GMT+8, 2025-12-22 19:07 , Processed in 0.419724 second(s), 7 queries , MemCached On.
